Question about Toro Garden
Rear wheel stuck on shaft
We have a punctured tyre on our Toro Workhorse mower. Trying to remove the wheel to take it to get the puncture fixed. I have removed the retaining bolt that locks the wheel to the drive shaft, but the wheel seems to be stuck on the shaft. Anyone know the safest way to free the wheel from the shaft? Thanks in advance, Keith
    Problem Solver:
  • 8 Answers
Should be ale to take the lug nuts off and simply take the tire off if it is stuck on after taking the lug nuts off take a 2x4 and hit the back side of the rim a untill it comes off they do tend to stick on the hub.
Posted on Jun 18, 2014
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
  • 203 Answers
SOURCE: I am trying to remove the belt cover on a self
Probably 1 or 2 more cover bolts holding it on. If you get the model number of the machine (not just the name) and go to Toro.com, down near the bottom on the left side will be a link to "homeowner parts", click that and you will get a new screen that allows you to put in your model number. Another screen opens and you can see several options. You want to "Look Up Parts" from the red flags at the bottom. Click that, you will get an opportunity to select "Handle Group", "Engine Group", "Deck and Self-Propelled", or similar choices. Look at the deck selection and you will see all parts involved, and you will see where there are screws or other attachments holding your belt cover on.
Posted on Oct 24, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
Knucklebstr
  • 222 Answers
SOURCE: I have a Toro self
It sounds like your belt is slipping / loose and should be replaced. Hope this helps. Good Luck.
James
Posted on May 27, 2011
  • 6468 Answers
SOURCE: I have a rear flat tyre on my lawnflite mower,does the holding bolt on the wheel undo clockwise or anti clockwise?
the bolt comes off counter clock wise but if the bolt is stuck the wheel will be also i just change them right on the mower
Posted on Apr 24, 2012
Puncture in one of my front tyre how do l remove it
To remove wheel there is one center bolt in the middle of the wheel(13mm). The wheel is a split rim so on the inside of the wheel there is more 13mm nuts undo them and the wheel comes apart.(no need for tire levers)
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
Tip
Removing a 'stuck-on' road wheel
It's dark, it's raining and you have a puncture and you can't get that punctured wheel and tyre off the hub! When you try pulling on the wheel/tyre, the vehicle almost falls off the jack and that could be dangerous. Best thing to do is find a hard piece of wood, about one and half meters in length, turn the steering wheel fully until the front of the wheel and tyre are exposed and then strike the inside rim of the wheel firmly with the wood - you'll find the wheel becomes free. Straighten the wheels and place replacement wheel and tyre on the hub. Scottech.
on Mar 16, 2010 | Honda Accord Cars & Trucks
Remove wheel husqvarna mower
Why do you not just pull the tyre off the rim on the outer side & check fot what caused the puncture/leak... Check the tyre valve first....
Dec 09, 2013 | Garden
Wheel stuck on shaft
make sure there aren't any c clips holding it on I would use a block of wood and a hammer I have put green slime in my tires that stuff works great it should fix your tire
Jul 26, 2013 | Toro Garden
Removal of rear wheel on a benelli tnt 1130
Hi Leslie, I am sorry you can't find the first and best tool you ever bought for your Benelli but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Delboy Garage Emergency Puncture Repair Motorcycle Tyre
How To Guide fix flat motorcycle tire
Benelli service manuals page 4
Benelli Manuals
https://dl.dropboxusercontent.com/u/35177464/Benelli/Katalog-d%C3%ADl%C5%AF-TNT-1130-Cafe-Racer-MY06-07.pdf
Aug 19, 2012 | 2011 Benelli TNT 1130 Cafe Racer
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
Mar 27, 2011 | Bebecar M City Stroller
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
I have a puncture in my rear tyre and for sum reason a cant get the spindle out to repair the puncture, is there a certain way the spindle needs to come out?
standard on most motorcyles,remove large nut from shaft. make sure chain adjusters are loose. tap shaft with hammer and drift to knock it out of the hub and springarm
Jul 19, 2009 | 2004 Derbi Senda R 125 4T
Tyre puncture
if it is an alloy wheel ,it may be stuck around the hub where the wheel is placed.sometime there is rust around the hub thus preventing the wheel from coming out.So you have to slightly kick the wheel tyre from behind hardly and it will come out and if necessary a bit hard.Thanks
Jun 22, 2008 | 2005 Ford Focus
Garden Logo
124 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
