Hannspree tv My remote's light won't turn off unless i press one of the numbers so i might need to enter a code but i don't know the code for a hannspree tv
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
1130. Check this code.
Posted on Jul 26, 2013
SOURCE: rmote control code
need a remote code for digimate tv dgl3201 thanks if you can help
Posted on Feb 29, 2008
SOURCE: Code needed for Sony rm ez4t remote control
Buy a learnable remote.
Posted on Jul 20, 2009
SOURCE: can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Posted on Dec 01, 2009
  • 18 Answers
SOURCE: 32 inch, hannspree tv.1080P I need
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Posted on Mar 15, 2011
diodeic
  • 1622 Answers
SOURCE: We have a 46 inch sharp tv model number 46SB54U
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Posted on Jun 25, 2011
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
The number 2 remote control do not work the remote
ramoshummer,
I would need more information to provide you a specific resolution, but below I have included basic steps to programming your remote to both your TV and your DISH Network receiver.
Link for codes if needed: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If those don't solve your problem or you're experiencing a different issue let me know here or at thomas.faust@dishnetwork.com and I will check it out!
Tommy Faust
DISH Network
Sep 08, 2011 | DISH Network IR Remote Control
I am trying to get the code numbers for Dynex tv
Unfortunately the user manual does not have a pre-programmed code for Dynex, so your best bet is going to be performing a code search.
To search:
1. Make sure the TV is on
2. Point the remote at the TV and hold down "CODE SEARCH" for at least 3 seconds, until the red light lights up solid
3. Press the "TV" button once and the light will blink once, then return solid red.
4. Press the On/Off button repeatedly until the TV turns off (go slowly enough that you don't keep pushing on/off after the TV turns off)
5. Once the TV turns off, press the ENTER button and the code will save (and the red light should go off)
This may take a while, so be patient, but if anything should get it working with your TV this will be your best bet.
Aug 25, 2011 | Innovage Jumbo Remote Control
Remote stopped working. How does one reset the remote?
Programming a code into a remote mode:
  1. Turn on the component to be programmed, then press the corresponding MODE button on the remote control. (TV, VCR, AUX, CABLE, ETC)
  2. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control.
  3. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming codes for the corresponding component can be found on the following website. Again, if the code is correct, the device will turn off.
  4. Press the MENU button to store the code. After blinking twice, this code is stored.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
I bought a new TV and need to program my Dish network remote control
Hey scrappy32847,
Congrats on the new TV! I can definitely assist you with this and get it taken care of. As I don't know what TV you have I don't have any codes off hand available.
You can check out this link: http://www.dishnetwork.com/SupportSection/remote-setup to get the codes to program your remote. I have also listed the steps below to program that remote to your new TV.
If you need any additional assistance you can reach me here or at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Jun 24, 2011 | DISH Network IR Remote Control
I have a haier tv a 722k receiver. my black dish network remote won't change inputs so i can use my ps3 etc.
allday70, we don't have any current codes for a Haier TV, but we can definitely check it out and help you get that programming.
As there are no codes for that TV, I would recommend trying a power scan. I have posted the steps below, though you can view this link: http://www.dishnetwork.com/SupportSection/remote-setup for general information on setting up remotes.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any questions or need further assistance!
Tommy Faust
DISH Network
Jun 18, 2011 | DISH Network IR Remote Control
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Apr 13, 2011 | Hannspree ST42DMSB 42 in. LCD TV
I need the 4 digit Hannspree manufacturer code to set up my UVerse remote control
AT&T don't list any codes for Hannspree, but I have it on good authority that either code 1004 or 1018 work for Hannspree. Others have reported that the some of the codes for Vizio TVs will also work. There are: 1489, 1429, 1433, 1439
If none of these codes work, please let me know and I'll try to find some alternatives. It would help if you could let me know the model number of your TV to narrow my search.
I'd also be grateful if you could let me know which, if any, of the above codes worked for future reference.
Regards,
BElectric
Dec 12, 2010 | Televison & Video
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Cannot program comcast remote to work with hannspree lcd tv 25"
try this
press tv button (lights up red)
hold setup button for 10 seconds (tv button blinks twice)
enter code 10030
Press power button on top right. If tv turns off your good
If it doesnt work follow steps above but try these other codes 11348, 11745, 11783
May 30, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
