Question about Sanyo Televison & Video
PLYBACK NUMBER OF ST-14SE1M - Sanyo Televison & Video
My tv 14" when you turn ON ok it will function but after a minute it will shoot OFF
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 07, 2015 | Sanyo Televison & Video
POWER SHUTDOWN KAPAG INI ON KO UNANG PLUG KO SA KORYENTE NAG ON AFTER 2ND OFF AGAIN MODEL ST-14SE1M
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 08, 2014 | Sanyo Televison & Video
Record/plyback
hit record and sing the song
hit the stop button
hit the eject button
insert the cd into the drive again
hit the play button
Apr 05, 2014 | Televison & Video
I have a grundig tv T55-549 i need replacement for plyback that suit to this model of tv.any suggestion from you is a big help for me.
Normally flyback transformers will not have any substitutions for any TVs. You must ahve its original number to replace.
Apr 16, 2012 | Grundig Televison & Video
PROMAC tv 21 need the schematic diagram model 2100CT
may tv promac 2100ct is no value number of plyback . what is the value the plyback use cineflat 2100 cts
Oct 01, 2011 | Televison & Video
Part number of plyback
I need the brand and model #
thanks
Jun 05, 2011 | Televison & Video
MY RCA 27" WILL NOT TURN ON, HAVE POWER TO THE FUSE, THE FUSE IS GOOD ALSO BUT THE DEGAUSS RELAY DOES NOT CLICK AND NO OTHER CLICKS ARE HEARD EITHER, WHAT COULD BE WRONG?
you need to check the voltage output of your power supply section.This power supply supply is a switching type power supply.there is a chopper transformer in there.its supply is a dc voltage unlike any other transformer which is AC supplied on the primary..First step.
1.Using a multitester measure the primary supply it is a DC voltage around 220v - 110 VDC
2.Measure the secondary output.The out put is AC voltage the supply for the B+ going to plyback is 115vdc the second output is 12v run through a regulator and the regulator lower the voltage to 5vdc.this 5vdc supplies the system IC and the jungle IC.this ic process the switching of the plyback transformer and the plyback transformers output supplies the voltage of the whole system including your relay in the degaussing section....once the plyback is activated the tv will now turn on...
good luck!Hope i helped you..
please rate my help..god bless!
Jun 13, 2010 | RCA F27641BC 27" TV
I have a sony kv-36hs20 that will not turn on it just clicks and the power lite flashes about three different codes i think thats what that means i worked in a tv shop yrs back and have a little experence
hello!since you have an experience in repair,try to have a voltage data on the circuits of your tv..check whether there is a supply output from the plyback secondary,does the heater of the picture tube is lit?if yes your plyback is working fine,,if not,check the horizontal output transistor for any leak,open or shorted.do it same to the regulator.if these two transistor is bad replace them..check also for any leak capacitors on your horizontal section.there might be a problem in there..same with the capacitors on the power supply section.If The plyback transformer is not switching replace the jungle ic.this ic generates the horizontal pulse to the plyback..good luck hope i helped you..
Jun 04, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
Sep 15, 2009 | Cobra 29 LTD CB Radio
I have had a Hitachi CM721F monitor for about 3 years now, and the focus is getting fuzzy. Is there any way to adjust the focus?? The brightness is fine. Thanks!! Dave Barnes, davidb1569@aol.com
If you can open your monitor you can adjust the focus in the back of the plyback of your monitor. But be careful to touch other parts of the monitor to avoid damage to the monitor in to your self. Use sharp thing or plastic to adjust the focus in the plyback. When you open the monitor cover you can find the plyback in the back end of the board of monitor usually color black and there are four wire connected to the board in the monitor yoke. Look for the two holes adjustment the upper one is for the bright and the lower one is for the focus. open the monitor and adjust the focus slowly again avoid to touch the other parts of the monitor. goodluck
Apr 16, 2008 | Computers & Internet
Televison & Video Logo
16 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
