helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
I have the same problem and have been crawling all over looking and haven't found a thing...I think it means the battery needs replaced...I charged mine with a diff charger than what came with it and after a few days it started blinking whether its plugged in or not. Have you charged yours with a diff charger?
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Most modern heat systems are controlled by vacuum there is a vacuum hose that comes in the psssenger compartment from the engine to the heater controls if this hose has a cut or is off or loose you could experience those types of symptoms . But if your system is contrilled by a cable and the cable is broken of has come off there is your problem.
Im guessing that you have either a vacuum hose off, or broken or....... the HEAD unit the heat control is bad
Please cntact me if you need any firther help and if you find this information helpful please ive me a fixya rating thank you, Randy [email protected]
Hi there! OK I know it is little late to response but if someone will google it,
might find the solution, they are still selling it though. I just got
my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small
power in it, however you have to charge it. So connect the small
charging cable into the base unit and the headset and make sure the
switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity
supply. Connect the audio connector from the base to the e.g. TV, PC,
DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have
two of the same wireless sets. So if on the base is set to # 1 the
headset needs to be also on # 1. Then if you have second headset choose
channel # 2 on the base and also on the headset # 2, so they are not
crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
