Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Water keeps overflowing out of the sump trey continue running
    Novelist:
    Champion:
  • Ice Expert
  • 373 Answers
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Posted on Jul 07, 2014
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
Im having issues with my tank overflowing
this device is a siphon overflow , care will need to be given in keeping it clean and sealed well or siphon will be lost and yes tank can overflow ive been told a small bubbler in middle section as a tickler will keep siphon going better , im not a great fan of siphon type over flows , but if you have the means a hole type overflow is far superior to this ,way less probelms
May 13, 2014 | CPR Aquatic CPR CS150 Overflow Box - 1600...
Water keeps running
where is the water running on the ice head or is this a remote water cooled condenser? If water is running all the time at the ice head into the sump tray and overflowing into the ice bin then check the water inlet valve ether rebuild or replace valve but make sure the water low sensor is not calling for water when the sump tray is full of water.
Jan 12, 2014 | Scotsman Cooled Modular Contour Cuber...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Have to keep adding water to overflow tank...Code read PO117 for mazda miata MX5
You have a leak in the radiator, water pump, a hose, the heater or a head gasket. Check these and see if there is any water coming out of the exhaust or in the sump.
Take off the radiator cap, fill it right up to the neck, start the engine and warm it up. See if there are any bubbles in the top of the radiator, keep it topped up so there is no room in the top tank.
If there are continuous bubbles then there is a leak in the head gasket.
Sep 08, 2011 | Mazda MX Cars & Trucks
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have a miele G841 dishwasher and the saftey pan is always filling up with water and then a intake - drain error code comes up and the dishwasher will not allow water to enter for rinse until I drain...
Hi dear.If you are handy enough,that's what you can check to make a solution for yourself.Goodluck.
Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?)
3. Check overflow float switch B8/3 for continuity and correct operation.
4. Carefully dry all electrical components in the drip pan area.
Cause:
Float switch defective.
Remedy:
Replace overflow float switch B8/3.
I hope that helps.Thanks.
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Takes too long to drop ice
Unit is functioning on the back up freeze timer.
Cause:
Float Switch stuck in the up position.=Empty sump, remove float switch (Carefully and watch the small pin that keeps the float inside). Clean and reassemble.
Water Valve leaking by:=Only fix is to replace. Turn unit off. If water continues to run in and overflows the sump, it's leaking.
The other things that can cause this requires a qualified tech as it is a refrigeration problem.
Hope this gets it for you.
Jul 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
166 people viewed this question
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
mike cooper
JoyEd Stevenson
JoyEd Stevenson
Level 1 Expert
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
