Question about Sewing Machines
Prolectrix sewing machine
The holder for the bobbin wont stay in place can you help
  • 9 Answers
SOURCE: Singer cg-590 floating bobbin keeps jumping out of it's holder.
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Posted on Feb 21, 2009
SOURCE: problems with prolectrix sewin machine
you have to make sure the bobbin thread is positioned right in the middle. When the needle comes down (into the bobbin compartment), you can peer into the bobbin compartment and see a loop of thread (coming out of the needle). You want to catch that bobbin (thread) in the loop of thread (that runs from the needle).
Posted on Feb 27, 2009
  • 192 Answers
SOURCE: bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
  • 5 Answers
SOURCE: Won't pick up bobbin thread
Does she have the right needle in? If the needle is to short it won't pick up the thread. If that is not the issue than it could be timing
Posted on Jul 29, 2009
My bobbin is stuck in the holder and wont come out
hi Linda,
this is all i could find out.
go to this link and you will see a youtube video might help you out.
How to Troubleshoot Bobbin Problems Sewing Machine
you could also try this link.
Bernina Sewing Machines bobbin is stuck in the holder and wont come out...
Dec 10, 2017 | Bernina Sewing Machines
How to place bobbin holder back into machine
the bobbin case probably needs to be replaced and the
hook and hook race may need to be check to see if something
is wrong with them.
Feb 06, 2013 | Elna Heirloom Edition 6005
Prolectrix bobbin
email these sites to see if they can tell you where to get bobbins
for the machine
sewvacdoctor.com
a1sewingmachines.com
Jun 07, 2012 | Sewing Machines
Bobbin case wont stay in place
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
Apr 19, 2012 | Janome Sewing Machines
Hi, the bobbin holder on my machine is not staying in place. It keeps moving when I stitch or move the needle turner. It just doesn't stay in place and therefore I cannot use the machine. Please let me...
I am wondering if you are using a different bobbin, in your manual, it specifically states that you have to use an SA 156 bobbin not one from an older machine. If, you do not use the right size it will act like you are talking about. I know that you should check that out.
Apr 17, 2011 | Brother XL-2230 Mechanical Sewing Machine
Bobbin case does not stay in place
I looked at the 4210, here http://www.singerco.com/accessories/manuals.html
And I do not see any adjustment. Refer to the page for installing the bobbin - are you using the right size bobbin?
Mar 31, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin holder falls out when I try to sew
What brand and model of sewing machine? May be able to find a graphic and instructions you can view.
Feb 21, 2010 | Sewing Machines
Feb 20, 2009 | Brother CS-8072 Computerized Sewing...
Problems with prolectrix sewin machine
Feb 15, 2009 | Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
