Question about Sharp XR-32X Projector
Replace dmd 1076-6319w - Sharp XR-32X Projector
Is there any possible way to repair a DMD chip with tiny white dots?
Anything is usually fixable. What you have to determine with Dell's assistance is if it is cost effective to do so.
Nov 26, 2015 | Dell 1209S DLP Projector
White spots on projector
firstly make a clean for your projector DMD chips or color weel, if it still ahs whie spots, It should be dead pixels, since for the DMD chips issue. you have to replace a new DMD chips. i have DMD chips fit for Optoma EP761, it will cost USD123 with shipping
Jan 11, 2013 | Optoma EP761 DLP Projector
Dmd chip change
if you are definite that Dmd is the fault yes you can replace, but you need to find exact replacement part.
Dec 26, 2012 | Dell Computers & Internet
My acer projector have a white dots whats the cause
It is because of the DMD chisp faulty, you have to buy a DMD chips replaced. fortunately, this model DMD chips is 8060-6038B, it is not expensive, and normal, for any fuIt is because of the DMD chisp faulty, you have to buy a DMD chips replaced.
for any further help, please contact merther help, please contact me
Nov 12, 2011 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
71 inch Samsung DLP TV with white dots model code HLS7178WX/XAA how do I fix
Buy a new DMD Chip and replace it yourself only cost you $159 which save at least $100 to ask a repairing center to do it for you. Check the video how to do this. Source: DMD Chip replacement tips And your DMD chip should looks like
Mar 16, 2011 | Samsung Televison & Video
Replace dmd board samsung hln507w1x/xaa
You will have a couple of problems here: This model may use 2 completely different DMD boards---need to get the right one.
Also, DMD is usually about 400 dollars and entire light engine with a new DMD is about 450-500-----they really don't want to sell them.
If you were to replace the DMD you would have to get at it (it is on the back of the optical engine and usually you have to remove another unit bolted up behind it, remove a fan in back of it and then release 3 long recessed bolts to take it out.
I did these and they are not easy---when you install the new DMD you have to POSITION THE DMD WITH THE SET ON---it will center the picture up/down and left right--moving it up slightly moves the picture down-----every action is opposite of what direction you move it.
Presuming you get it centered you have to tighten the three bolts slowly---as you tighten they tend to move the picture in some direction.
I think you get the idea---the DMD is not a "easy" part to properly replace.
The shop I work for---we have tossed several of these sets to be recycled as the cost of the part is more than the set is worth used.
If this information told you something you did not know, rate this solution as I do this here for free.
You may also want to contact SAMSUNG as there have been some programs where they will cover the replacement because so many failed and lawsuits were started etc.
REGARDS, SD TECH
Aug 13, 2010 | Samsung Televison & Video
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Dot all over tv samsung hls4266wx/xaa
You need to replace the dmd board.In some cases it is more cost effective to replace the entire optical engine which includes the dmd board,lamp,ballast and color wheel for about the same amount of money and is easier to install.
Aug 22, 2009 | Samsung HLS4266 TV
Sharp XR-32X Projector Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
