Question about Hoover Vacuums
Customerservice how do you remove the filter on a hoover nano-it looks like you could twist it off but it won't budge
  • Hoover Master
  • 18,402 Answers
Yes it does unscrew it will be tight and you will need alot of presure to unscrew try tapping it with a screwdriver handle turnig it the link below is the manual page 10 is filter change.
http://hoover.com/file/979/http://hoover.com/file/979/
Posted on Jul 26, 2013
Hoover Windtunnel 2. Trying to twist open the lid from the bottom to clean. It doesn't want to budge. Is there a lock or a latch somewhere?
Stand over a garbage can. Ready? The bottom opens like a trap door would. No twisting, look for a little flap and knock the swinging door down.
Nov 18, 2016 | Hoover Vacuums
My hoover nano cyclonic just shut off
It has likely overheated. Let it cool down and see if it comes back on. If so that means something is causing an airflow restriction. Replace filters and check for clogs
Jan 22, 2016 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won't power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
Why does it shut off after 10 minutes?
Hi Will! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
Jul 27, 2014 | Hoover Nano Cyclonic Compact Bagless...
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Hope this was helpful!
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
I cannot remove filter from Black and Decker PHV1800
yes you are doing it right it should only turn about 1/4 inch then pull out go to this link for manual and diagram it ma help you..
http://servicenet.blackanddecker.com/Products/Detail/PHV1800
Dec 18, 2012 | Black & Decker PHV1800 Bagless Handheld...
Hoover F5909-900...can't find manual. Can you
Check out Hoover US website on:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
There's a telephone number you can call if you can't find the user manual you are looking for.
Mar 04, 2009 | Hoover F5870-900 SteamVac Vacuum
Vacuums Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
