Question about Ahead Software Nero 6.0 (60045) for PC
Burning what do u mean by the word Burning. is the cd is really burning. how is it happen. how its works. what material is used for burning. why other components not get damaged by burning. please give me the soluion. please...
  • 12,061 Answers
What is meant by "Burning" is that in the CD/DVD There is a "Head" inside which is a "Solid State Laser Beam Generator" this "Beam" is then "Modulated" by the "Recording" (Burning) software in such a way that it causes an actual "Burnt Area" to be formed on the "Substrate" of the CD/DVD "Medium". This "Area" is then able to B "Read" via another laser & using the "Reflected Light" is "Sensed" by a "Detector" area in the Laser "Head" that translates the resultant signal, when played back.. So really the word "Burn" is just a "catch phrase" to indicate the "Recording" proceedure of data transfer on a CD/DVD.
Posted on Aug 30, 2007
Error . Cannot continue with the burning process, because no burning device Was detected. Install a burning device and restart burning program
Will it burn stuff okay using windows native burning support? If not, go here and download the CD Gone utility. Next, uninstall your CD/DVD drive in Device Manager, run the utility, and reboot. Your drive will be re-installed, and should work properly, unless it has mechanical/firmware problems. This is a Registry patch program, and fixes a problem that frequently happens. HTH.
Sep 29, 2013 | HP Computers & Internet
What's the difference between burning a cd and burning an image
Burning an image file (ISO) means that you will burn and finalize the disc. The ISO file includes a "boot sector". This will create a disc that can be used as a boot CD. Make sure that the ISO is <700 MB if you burn to CD; if it is larger, use a DVD or DVD DL. Some image files may have an IMG file type (this was the file type for bootable floppies). Unless the file is an ISO or IMG, the burn image function will not work. You will need to use another program to make an image file first. You may need to use a bootable disc to get the information for the boot sector.
Burning a CD creates a data CD which may or may not be finalized, depending on your settings.
I hope this helps.
Mar 04, 2013 | Roxio Easy CD & DVD Creator 6...
Aspire, M3410, problem with cd burner
Ive had this same thing happen to me over the years and ruined many CDs. Im not really sure why it does this unfortunately. I too have tried a few diffrent burning programs. Sometimes, however, Ive noticed tht its the same songs that mess up on each burn. Ive tried to reburn using diffrent songs and put the ones tht it skipped or were "blank" on on the new cd N it didnt work then either. The only solution I ever came up with was that it was the song itself wouldnt burn for some reason. Try redownloading the song from a diffrent site and see if the new one burns. I hope this helps some in your problem.
Jun 06, 2012 | Acer Aspire M3410-UR21P : 3.1GHz Athlon II...
I can't burn a cd-r disk and i use to be able to what would cause this problem and can it be fixed
What happens when you attempt to burn a CD-r?
Try burning it with another burning program like CDBurnerXP - http://cdburnerxp.se/
And let me know how it goes.
Thanks
Sep 11, 2009 | Microsoft Windows XP Home Edition
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
CD Burning
i would try to dl latest nero.com use nero alot better did u try to go to roxio.com and download latest software verison k thx nick
Oct 06, 2008 | Roxio Easy CD & DVD Burning
Philips dvd burn not burning?
1. see to it that you have set your burning software to write to the disk.
2. try to use it on a cd, if it finishes the job, something is wron with your dvd drive.
3. make sure that the drive you have is really a dvddrive and not a cd drive.
4. upgrade youe burning software.
Jan 05, 2008 | Philips (JR4DVDRWK/00) DVD+RW Burner
Burned CDs don't play properly
if it won't play right when you put it in the cd player....it may be that the burning system that you're using is off and needs to be updated or trashed for a new one...got that?
Oct 22, 2006 | Ricoh (RW7083A) CD-RW Burner
Ahead Software Nero 6.0 (60045) for PC Logo
57 people viewed this question
Top Ahead Software Computers & Internet Experts
Alun Cox
skyocean
Level 1 Expert
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
