Question about Holman QCS2-600H Conveyor Toaster
Hi,only 1 heating element is working out of 2 on the bottom and the 2 elements on top quit working. I replaced the 3 bad elements, double-checked the wiring schematics and all 3 elements still don't work. Could the problem be related to the EGO infinite switch or the high limit switch? Help much appreciated. Thank you.
2 Suggested Answers
  • 10865 Answers
SOURCE: Need the part number for a heating element for a
Hello. The heating element part number is
HD-198042. There are six heating elements in your toaster.
AND here is the downloadable manual
http://www.star-mfg.com/documents/service_docs/Holman_Ovens-Toasters/Conveyor_Toasters/Older_Styles/9H-QCS2_-_RCS2_Series_Sticker_Nameplate/C_QCS2-300H_-_QCS2-500_-_QCS2-600H_-_QCS2-800_-_RCS2-500_-_RCS2-600H_-_RCS2-800_-_2M-HG0651.pdf
Regards, Joe
ps -- kindly rate my answer as helpful. thank you.
Posted on Feb 16, 2010
Testimonial: "Great Job! Thanks SMCR"
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Have a new electric tank,top element wont come on,replaced thermostat 3 times top element comes on once but next morning not enough hot water&top element wont come on,can someone help? thanks
The top element only comes on when the heater is about out of water. The water is directed to the bottom of the tank. Cold water stays on bottom, Bottom heater element heats water. If you use all that water then the top of the tank gets cold and the top element comes. When the top of the tank is warm, then the bottom element comes on. I would susupect the bottom element as it does most of the work. If you have an ohm meter, turn off electric, and remove wires from element. Check element for continuity. If you don't get reading, then that element is bad.
Oct 04, 2010 | General Electric Water Heaters
Oven heating element will not heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | Ovens
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Top oven will not turn on elements, bottom oven turns on elements
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
Dryer just quit heating
First-***DISCONNECT THE ELECTRICITY***. Open the back of the dryer. The element will be in a flat metal tube running from the top to the bottom of the back of the dryer. There will be a few wires connected to it. Mark where these go for reassembly. The heater wires are inside the tube. The whole assembly comes apart quite easily to replace the element. It looks like a stretched out spring.
May 02, 2009 | Whirlpool LER5636L Electric Dryer
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Holman QCS2-600H Conveyor Toaster Logo
Top Holman Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Holman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
