Question about HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522nf error # 5
We are getting Scanner Error 5 on initialization (repeateable). Does anyone know what the error means?
    Top Expert:
  • HP Master
  • 12,223 Answers
Go to www8.hp.com and get the support via ONLINE chat free for fix
it the error # 5.
God bless you
Posted on Jul 26, 2013
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
Dadofmykids
  • 25 Answers
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Posted on Apr 07, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
  • 121 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
sandimcp
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
Scanner error 5 turn off then on
Scanner error #, Turn off then on The product has experienced an error in the
scanner sub-assembly area.
power and wait for the product to initialize.
If a surge protector is being used, remove it.
Plug the product directly into the wall socket.
Use the power switch to turn the product on.
If the error persists, contact HP. Or replace the printer. The repair is too expensive.
Feb 12, 2014 | HP LaserJet M1522nf Multifunction Printer...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Hpm1522nf - scanner error 8
Replace Optical Scanner Assembly(CCD).. Some technical knolwdge required to replace this part.. See the part:
Jan 08, 2013 | HP LaserJet M1522nf Multifunction Printer...
When scanning or copying from hp laserjet 1522NF error message show 52 errors then turn off
52 error is a scanner error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see www.hp.com/support/ljm1522 or the support flyer that came in the product box.
Jun 16, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet m1522nf. when you print it states scanner error 5 turn off then on
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
Apr 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp m1522nf: Keep getting scanner error5. Don't use the scanner but not I can't copy with this error.
Hello !
I worked with those printer for 2 years...
This scanner error 5 you are getting is hardware failure on the scanner assembly
I would recommend you to try updating the firmware to the latest version, but most of the time its not going to work.
Now heres the best solution:
If the printer its under warranty (1 year after purchase date) just call hp tech support and you can get a replacement for $69 US dolars
its better than buying the scanner assembly
If the printer its out of the 1 year warranty, theres a service note for this specific issue that will extend your warranty 1 more year, that means 2 years warranty if the problem is a scanner error 5
Hp tech support phone number is 1 800 334 51 44
If you have any other question just contact me at :
eliteprintersolutions@hp.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP LaserJet M1522n MultiFunction Printer Logo
863 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
