Question about Canon MV800i Mini DV Digital Camcorder
I have a problem about red symbol blinking every time when put on the camera. the symbol look like the power card.
I have the Canon 650D and my access lamp is red and blinks at times. Usually when i take or view an image. I googled it and it told me to format the card. I did that and now my card is empty with no...
Formatting the card (as it will say in the menu and on the on-screen instructions when you perform this action) deletes all the data currently resident on the card. You may be able to use data recovery software to retreive them.
May 04, 2017 | Cameras
I am putting fully charged battery but it is blinking red for charging the battery
I had this problem. If you have the original Nikon charger, insert the battery and press the calibration button. I dont know how, but it charged the battery fully.
Sep 25, 2012 | Canon PowerShot A470 Digital Camera
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
I'm trying to upload the pictures on my Canon EOS Rebel T2i and the red light is blinking with nothing coming up on my computer... please help!
red blinking is memory card activity so should wait. try putting the camera into playback mode when connecting to a computer and computer should come up with a range of options. if all things fail go get yourself a memory card reader and take the card out of the camera and transfer your photos that way. its better on your cameras battery life and its quicker
Feb 15, 2011 | Canon EOS 550D Rebel T2i Digital Camera
How do I add pictures onto my computer with the Olympus u tough 3005? I have tried taking the memory card and putting it into this little slot in my printer for digital camera memory cards, and usually...
The cause of this is probably an incompatibility between your memory card and the card reader in your printer. Your camera is fairly new, and you probably have a memory card of 4Gb or more, which is going to be SDHC. Your printer is probably older, and is only compatible with SD (generally cards up to 2Gb).
Your solution is to use only SD cards, which essentially means limiting yourself to 2Gb, or buying a card reader which can support SDHC. I don't know what country you're in, but I bought a SDHC card reader in a dollar store for $2.00 which is half the price of a large latte.
Jan 23, 2011 | Olympus TOUGH3000 Digital Camera
I have a casio exilim ex z77. My battery to my camera wont charge when I put it on the charger. The red light just blinks.
hi, once you charge your battery and the red light blink it means your NP-20 battery is damage and you need to buy new one.TIP- charge 1.5 hours only and if youre not using you camera for a long time its better to remove the battery.
good luck and thank you my friend
Jul 08, 2010 | Casio EXILIM Card EX-S770 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Warning symbol
Problem with Nikon 4600, system error 1 0 after a memory card used in a Nokia set , any solution
Mar 20, 2008 | Nikon Coolpix 4600 Digital Camera
Canon MV800i Mini DV Digital Camcorder Logo
16 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
