Question about HP Jornada 540 Pocket PC
Hp jornada 540 sd memory card
Hi, I have a hp jornada 540 series, i want to extend the memory by using any of the compact flash type I card which supports my PDA but I do not whats max size can support my PDA. If any one help me out?
5 Suggested Answers
sksree406
  • 61 Answers
SOURCE: HP IPAQ H4150 + Memory Cards
Dear friend,
Devices will need the SD 1.1 standard in order to operate with 4GB SD and your PDA is comes with SD 1.0 (SD/IO 1.0) standard.Max memmory you can support is upto 2GB
Posted on Oct 30, 2008
adib
  • 450 Answers
SOURCE: change language in hp jornada 540 pocket pc
Sorry, the OS on the Jornada 540 is in ROM and cannot be changed.
Posted on Sep 12, 2005
tukidoman
  • 80 Answers
SOURCE: HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Posted on Nov 15, 2008
SOURCE: what maximum size SD card should I use?
You can go up to a 4 GB but needs to be a non HC SD card. There are companies that still have them. I found some at MemoryTen.com.
Posted on Jul 03, 2010
How do i repair sandisk micro sd card
Hi....
If you lost your data from sandisk memory card then you can use one of the sandisk memory card recovery software that is available online in order to recover files from sandisk memory card.
Dec 06, 2012 | Samsung 8gb Micro Sd Memory Card 4 Galaxy...
Windows vista not compatible with pentax optio 33l
If you're using an sd card or most other standard memory cards you can buy a card reader very cheaply and plug it into the usb of your computer, your computer may even have a reader built in
Sep 03, 2009 | Pentax Optio 33L Digital Camera
Memory card issue with Epson r300
Hi , reinstall the printer driver with sd inserted.
Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Pocket Access - does it exist on HP540?
No, sorry, the Jornada 540 does not have Pocket Access on it. The Jornada 720 does, however...
Sep 12, 2005 | HP Jornada 540 Pocket PC
Memory
There is the extended battery pack adds an MMC slot and leaves the CF slot open... So you could use the CF for the Wireless LAN and the MMC for extra memory...
Sep 12, 2005 | HP Jornada 567
CF for Jornada 525
The only advice that I could offer is to try those 2 Compact Flash cards on someone elses PocketPC. If they don't work then there must be something wrong with the cards. However, if they both work then there must be a problem with the CF slot on your Jornada. Try to test out some CF cards from an electronic store if they will let you. Yes, you do not need drivers for CF cards. A preferred CF list? Whomever told you this is blowing you off. People use all brands of CF cards from Viking, Scandisk, Lexar, Mr. Flash, etc. Sometimes there is a bad card and other times the CF slot is bad so check both of those out...
Sep 12, 2005 | HP Jornada 525 Pocket PC
Change language in hp jornada 540 pocket pc
Contact Transfer for Journada 540?
The Jornada 540 should have come with Outlook 2000. It works fine in Windows XP. When you Sync your computer and Jornada 560, the contact information should transfer from one to the other until both have the same contact information. Under the Tools pulldown on Activesync, select Options. Sync Options allows you to sync your Contacts by checking the box next to it. The next time you sync, all of your contacts from your 560 will be in your Outlook. When you get your battery replaced, just sync again and all of the contacts in your Outlook should transfer back to your 560. The other option is to get a Compact Flash memory card and backup your info onto that. Its much easier. Simply restore your info from your memory card when the battery is replaced. Hope that helped you.
O/s upgrade?
Sorry, the Jornada 540 has the OS in ROM and is not upgradable. Additionally, the 540 uses the SH3 processor which Microsoft does not support in the more recent versions of the OS.
HP Jornada 540 Pocket PC Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
