Question about Clothing Accessories
Clipart of GREASE the movie - Clothing Accessories
New clipart goes behind the page, I can't bring it forward
If you are working out of page in coreldraw then this problem occur, work within the page area, if still this problem occur copy that page to new untitled page.
Apr 02, 2013 | Corel DRAW Graphic suite x3
Where can I get clip arts or images to use with XsitePro? Thanks.
Hi gus,
Check out these sites:
http://www.xsitepro.com/clip-art-library-video-tutorial-for-xsitepro-website-design-software.html
This is from XsitePro's FAQ
14. Where do I get the extra clipart and templates from?
When you purchased XSitePro you became eligible to download the full Resources Pack (full of Clipart, Templates and more) along with a 'bonus template pack'. All of these Resources can be accessed from the bonus downloads page.
Here is another article that might help you:
http://www.warriorforum.com/main-internet-marketing-discussion-forum/206067-xsite-pro2-help-clipart-import.html
Hope this helps you.
Dec 22, 2010 | Intellimon XHeader
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
CANNOT INSTALL CDEARTH CLIPART CD TO MY DESKTOP
What program do you want to use the clip arts with? I have seen this before, and you don't have to install anything to use the clips. Technically you can just leave them on the disk. When you open the disk though, and see the different category folders, highlight one by clicking it once with your mouse, then right-click and choose COPY. Minimize the window and then open My Documents and then My Pictures. Right-click an empty space in this window and choose Paste. This will transfer a copy of these clips to your computers hard drive. Then open the program you want to use them with and find the option that will let you insert an image or clip art and then browse to your My Pictures location that you copied the folder to. Let me know the program you want to use the clips with, though, and I can give you more help.
Mar 30, 2009 | Computers & Internet
Office 2007 Clipart problem
Please copy the contents of CDROM to your HDD and run the setup from HDD only. here i mean, you should initiate the cliparts setup through setup.exe on your HDD.
It will resolve. i guess cause of problem is, you've installed the Office 2K7 from other drive and trying to install the Cliparts from different one.
May be you can insert the CD to the same drive from where you have installed office 2K7.
OR insert the Office 2K7 CD and run setup again for Modification and check the checkbox for Cliparts as well this time.
It will be installed without any problems.
Thanks.
Mar 17, 2009 | Microsoft Office Professional 2007 Full...
Microsoft Word 2007 would not allow me to insert clipart into the document I created.
hi,
Please verify that your office installation contains the cliparts modules installed on your system, else, you need to re-install and customize the installation to include clipart module as well.
Need some more info, if the problem still persists:
I got your problem but to get into the root cause I'll need more details viz.
1. Installation type of your Office 2007 package (typical, full, custom); just to make sure that you have cliparts installed with office package.
2. It would be more easy for us, if you can provide us the screen shot as well of the problem.
Mar 11, 2009 | Microsoft Windows XP Professional
When I click to add clip art o power point none of the pictures are displayed
Hello, this is Baris,
You may want to go to your clipart folder and see if there are any pictures in there.
C:\Program Files\Microsoft Office\CLIPART\
If not, you may want to go to microsoft web site and download some. They are free... Good luck :)
http://office.microsoft.com/en-us/clipart/default.aspx
Feb 27, 2009 | Microsoft Office Standard for PC
Where i should find free download of powerpoint+templates+clipart
Microsoft has a collection of free PowerPoint templates for download. You could adapt one of these presentations for your own subject matter. There are also more than 150,000 free clipart images you can browse -- scroll to the bottom of the page to browse by category, or type a search term in the box at the top of the page.
Hope this helps!
~~Cheryl
Dec 01, 2008 | Microsoft Office Professional 2007 Full...
Movie freezes
Grease the slide rails with a little smudge of vaseline - especially if the mechanism is noisy. There is another reason for it that I have not worked out, but on 2 machines the grease did the trick.
Jan 18, 2007 | Polaroid PDV-0700 Portable DVD Player
Clothing Accessories Logo
50 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
