All of a sudden I can't attach files to my email accounts (both yahoo and Hotmail) they just pend for ages but never attach.
SOURCE: attachment problem with Gateway Visa Home Premium
wt type of acc do u have are u using outlook win mail???
or regular yahoo etc??
try window restore to earlier date
and then check!!!!
SOURCE: windows email
IS YOUR EXCEL 2003 OR 2007. I WILL TRY MS OFFICE 2007
BECAUSE VISTA SOMETIMES HAVE PROBLEM READING SOME PROGRAM IN MS OFFICE IN 2003. EVEN WORD 2003 SOMETIMES HAVE PROBLEM IN VISTA. DEPAND ON THE COPY YOU INSTALL. I HAD PROBLEM WITH IT SO MANY TIMES
GOOD LUCK
SOURCE: Email anti virus will not allow access to email attachments
Hello my friend,
Regarding on your problem, email has an antivirus that will scan all attached files before it sends to the sender. So that part of their security to ensure the safety of the data in their client. So i recommend that if you send some files over emai lmake it sure that the file you attached is virus free. You can scan it first in your compter before you can attached it in the email. Or avoid sending files.exe extension to avoid the block.
Hope this suggestion helps you to understand the reason why this things happen and able to help your problem solve.
If you need more assistance just reply to this post. thank you
SOURCE: Cannot open some pdf attachments, and cannot open
Best way to open PDF documents is to install one of this:
Foxit PDF Viewer (free) - Download here:
http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html?part=dl-116442&subj=dl&tag=button
or
Adobe PDF Reader (free)
I recommend 1st one.
If you cannot open .doc documents it means they could be damaged or incompatible (less probably) with MS Office 2007, try to open with 2003 compatibility.
Windows Live Hotmail allows users to view attachments within a Web browser or save them to the system's hard drive.
If Hotmail can't open an attachment, the problem lies with an incompatible file format or Hotmail's automatic blocking service.
You may need new software installed on your computer IE: adobe . direct x , zip for opening unfamiliar formats, while blocked files are permanently inaccessible from within Hotmail.
Accessing these files requires action by the sender or forwarding the file to a different email client.
Incompatible File Format
Occasionally a sender may attach a file that simply doesn't work with any software you have installed on the system.
Attempting to open the attachment will result in a "Windows cannot open this file" message or similar error display.
Many programs use very specific file formats that don't operate with most other software, such as Photoshop's PSD image files or Microsoft PowerPoint's PPT files.
Ask the sender to convert the file to a more widely compatible format, or install the appropriate software on the system to open the attachment.
Blocked Attachments
Hotmail blocks attachments it believes may contain unsafe or otherwise malicious code.
This includes any and all executable file types, including MSI, EXE, HTML, STC and COM files, along with many others.
Attachments blocked in this way result in a "Windows Live Hotmail has blocked some attachments" message when viewing the email.
While this service does block many real threats to system security, Hotmail may occasionally deny access to an item from a trusted sender.
Unfortunately, these files become permanently inaccessible once blocked by Hotmail, and accessing them requires using a workaround outside the Hotmail application.
Only attempt to access attachments you trust as safe.
Forward Workaround
While Hotmail cannot open blocked attachments, it allows users to forward the message with the blocked file still attached.
Send the file to a different email client, and open the attachment using that account instead.
Note other clients may have different security measures, but some will still block access to executable files and other potentially harmful data.
Compression Workaround
Ask the sender to package the attachment into a ZIP, RAR or other compressed file format before attaching.
Hotmail will not block any file type located inside a compressed archive.
Both Windows and OS X can create compressed ZIP files, and free utilities such as Zipeg and 7-Zip can create many other types of archives as well.
Some email clients, such as Gmail, will not allow users to send some file formats, even when packaged into an archive file.
Hope this helps
