Question about Electrolux Garden
Partner colibri servicemanual - Electrolux Garden
Which fuel line goes where on Colibri Partner strimmer
the carby to tank
use the primer button to check lines are correct
once you get fuel in the primer
Flymo Partner Colibri SST250
trial and error
the longest hose
in tank filter line through the tank grommet to carby
short single hose
the other outlet goes from the carby back through the grommet into the upper part of the tank
Sep 08, 2016 | Garden
I have a partner colibri strimmer. How do I lock the driveshaft to change the line spool head ?
You should have a small hole in the side of the head that a small rod goes in to lock it. Just line the holes up and stick the rod or a nail in there and it should be locked.
Jul 11, 2014 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
Colibri where to buy new watchband colibri cxw95612
jewelry-watches.pricegrabber.com
or
cgi.ebay.com
or others
Aug 05, 2009 | Watches
How do I change the date on a Colibri Pocket Watch?
Usually all quartz watches are supplied with calendar setting mechanism and it is very simple-
try to pull out crown and you will notice that there are two clicks,so, when the crown is pulled out to the first click, the date can be adjusted by the turn of the crown. When crown is pulled further out (second click)- the watch is in hand setting position and you can adjust time.
Did it help?
Dec 15, 2008 | Colibri PWS-95877-N Pocket Watch
Garden Logo
50 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
