Wing w7562 pda problem
Pda not working properly
I am trying to get email access. I am not able to get my email even though my PDA says that it is connecting to my Wi-Fi
First you have to ensure that the problem is not from the internet connection. Try using the PDA and the same wireless connection to open a different site which is different from the email provider. If the other site opens then you are sure that the problem is from either the phone or the email service provider.
On the other hand if it does not open then this means that the recommended settings which are expected for the PDA to work with the wifi have not been properly set to give the PDA internet access. The device might be connected to the wifi but not connected to access the internet from the device. Try setting up the PDA and this time take care of the settings.
Hope this solution has been helpful?
Jan 08, 2011 | HP iPAQ H5550 Pocket PC
I have a Royal ezVue 7 PDA and I can't get the sync software to work. The computer reads and installs the software from the CD, and the desktop software appears to work, but to sync the desktop to the PDA...
Royal Extreme 7 will not sync properly.
It gets to Deleteing records and locks up.
Both the software and the PDA is then locked into the sync mode.
I have installed newer drivers as instructed by Tech support.
(MwNTXP.inf & rylm100.sys Files)
These files are listed under PDO Desktop>Drivers>WinNY2KXP.
I am using Windows XP Media Center Edition.
I have version 1.5 of the PDO Desktop program.
Is there a later version that works.
Frank Mattox
Sep 01, 2010 | Royal ezVue 7
Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Dec 10, 2008 | Computers & Internet
Touchscreen dosnt work properly, i click on the menu button and it usually comes up contacts instaed, then i cant go back it just freezes and no buttons work, i have to switch it of to get back to normal...
are you working on a PDA?? try to reset your pda (at the back or close to the edges look for a a little hole... with something pointy push inside the hole gently)
you may also want to recalibrate your screen... if it's a pocket pc what you have go into start>settings>system and look for self test or screen (to align your screen).
Sep 28, 2008 | Computers & Internet
My tmobile wing does not urn on
hi there it seems some problme with the software you install on the PDA... you need to hare reset your phone,,,,
hard rest your pda usnig camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........and you will back in business again....
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 25, 2008 | T-Mobile Wing™ Smartphone
Rained on T-Mobile Wing
While holding down the soft keys insert the stylus into the side of the phone (small hole on left hand side) should bring up a prompt to say if you continue you will reset your device....if you can get to setting there is a clear storage option, both master reset device. Good luck..
Jan 11, 2008 | T-Mobile Wing™ Smartphone
Myfaves profile editing
I would recommend resetting the PDA. Basically go into the settings and hit the clear storage button. This should solve your problem.
Sep 09, 2007 | T-Mobile Wing™ Smartphone
WRONG VOLTAGE
no as long the player is not damage you can still match the voltage because the 12v is not going to turn on or work properly on the h320 because the voltage is not right. Unless if you have a closer voltage like 4.5v or 5.2 v it will be good it will work.
Example:When i bought my pda it did not come with adapter so they gave me an alternative adapter is supposed to 5v but they gave me 6v to try out first it work then second try i turn my pda using the ac it have problem with voltage because is too high than 5v. The next thing i did is buy another adapter good thing i found closer to 5v which is 5.2v which is it work.....now by pda work..properly and i can charge it properly too.. well it takes sometime to look around the shop until it can be found the right adapter....
Well i used the USB to AC adapter 5.2v...it work great... for mp3 player like h320,pda........
Mar 04, 2007 | iRiver H320 MP3 Player
WIFI and SDIO
Are you sure your PDA supports Wifi through SD? I have only found information that suggests BlueTooth.
Sep 15, 2005 | Toshiba e330 Pocket PC
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
