Question about Health & Beauty
HuBDIC Blood Pressure Unit
Shows 'Er 5' message on screen. What does this mean and how is it resolved?
  • 2712 Answers
SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: Only blood pressure result I get is 'EE'
That either means you are moving, or you are inflating the cuff to soon after turning it on. Either of these is what mine means when I use it.
Posted on Jan 19, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: error 5
#5 error keeps coming up when bp taken with new batteries
Posted on Jun 24, 2010
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
LCD shows "Er7"
EEPROM accessing er-
ror
LCD twinkling
Device
parameter
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
http://webcache.googleusercontent.com/search?q=cache:V0KPe0jswmgJ:www.hmm.info/uploads/tx_sbdownloader/smartLAB_profi_user_manual_ENGLISCH_R4.pdf+&cd=2&hl=en&ct=clnk&gl=us&client=firefox-b-1
Dec 21, 2017 | Health & Beauty
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
What does it mean in the bottom left when it reads 60 then flashes to 01? can't get another reading
The "60" number reading that came onto the screen was your pulse rate. If you can't get the monitor to check your blood pressure again, you may need to replace the batteries, the charge may be too low in them.
Sep 24, 2012 | Mabis ® Automatic Premium Blood Pressure...
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
We have model 6053 braun blood pressure monitor. When we turn it on the screen shows err and that's all it has new batterys. Can it be reset? We don't have a manual. Thanks joe
I checked, and, unfortunately, they don't have instructions for your model.
Kaz has taken over Braun's BP monitor business, and one of the models' instructions says to have it seen by a servicer if it keeps displaying an error message. You can find one by calling:
Customer Service Information - North America 1-800-327-7226
You can also send email inquiries to ConsumerRelations@kaz.com.
Website: www.kaz.com/braun
Good luck, and I hope this helps!
Jul 01, 2011 | Braun Health & Beauty
What exactly does the MAP/cuff mean or measure?
Basically, the ProCare Series Monitor, is used in a hospital setting, on patients being transported from surgery, tests, ER, etc. back to their rooms. It's monitors their heart rate, blood pressure, breathing & pulse rate, as well as acting as a portable EKG machine. It alerts the transporter of any significant changes in the patient's condition, that would require immediate action, to save the patient's life. It records & stores all that data, for later review, if necessary.
Hope this helped you.
Jun 23, 2011 | General Electric Dinamap ProCare Series...
I NEED AN OWNERS MANUAL FOR BA-616W ...GOT IT 2 YRS AGO AND ONLY HAVE THE INSTRUCTION SHEET ..BUT I NEED TO KNOW HOW TO READ THE NUMBERS AND WHAT THEY MEAN. PLEASE HELP
As a 30 year EMT, I think I can help you.
There's 2 numbers that make up your blood pressure. The top number is called the Systolic pressure. The bottom number is call the Diastolic pressure. When a blood pressure is taken, it's measuring the pressure that the heart is producing when it pumps blood through the arteries. For example, what's considered a normal blood pressure in a healthy individual is in the range of 120/80. Of course age, life style and other health conditions, play a role in what yours may be. A person with High blood pressure or Hypertension would have a blood pressure of over 160 - Systolic and over 90+ Diastolic. 90 is actually the borderline for hypertension. That's why I indicated 90+.
The other reading on your monitor is your heart rate or pulse rate. It's how many beats your heart completes in one minute. It also indicates an irregular heart beat by the showing a small LED window on the left of the screen adjacent to the Systolic pressure reading, It will say IHB. Any movement or shaking or talking during the measurement can result in pulse irregularities. So hold very still when taking your blood pressure. This irregularity by itself is not of much concern, unless it shows up frequently. In which case, you should seek medical advice.
That covers just about all there is to know about what the readings mean. Armed with this, you should be able to effectively monitor your blood pressure and pulse rate and report them to your doctor.
Hope I was able to help you understand how it works and what it's telling you. if so, please let me know, by rating my response to you. Thanks and have a healthy day.
Apr 28, 2011 | Walgreens By HoMedics Automatic Wrist...
My glucometer Accu Check is giving me the error message E-5 and wont work
Since you didn't mention which model Accu Check Meter you have. E-5 means different things. In which case, I am going to direct you to a link, where you can find your Model and then discovery what the E-5 Error Message means.
https://www.accu-chek.com/us/customer-care/screen-messages/error-codes.html
Hope this helps you.
Apr 13, 2011 | Health & Beauty
I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
Feb 09, 2010 | Health & Beauty
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
