Question about RIM BlackBerry 8800
Broken mini usb port
The mini usb port on my t-mobile 8800 broke yesterday by me jiggling the cable to connect to the wall charger as the cable would not go back into the port. T-mobile will not replace it due to "water damage" that is indicated in the battery compartment. I have no idea how that happened. I am a 53 year old totally disabled, confined to a hospital bed and a wheelchair. I have been hospitalized for the past two weeks and still am. I have had this phone a total of 4 months, of which two I have been in the hospital. Anyway is there a way of fixing the port and has anyone gotten a false positive on any "water damage?" Thank you, Bob54
  • 1 more comment
  • bsquared2 Mar 07, 2008
    I noticed that my BB didn't charge last night and have discovered an apparent bad prong and connection. When I plug in the charge, it's very wiggly and the charge indicator goes on for a second but does not stay on. I'm sure that this has happened numerous times. Anyone have a good solution?
  • Bret Stray Jun 12, 2008
    Same thing just USB rattle. its loose so its impossible to get the the charger to "stick" in the port. I found a device online that was a solder-on piece for the USB. whatever that means? I would be willing to take the chance but it was like 50 bucks. Any alternatives to just charge the battery someone please?
  • Anonymous Jan 17, 2009
    i have a bb 8800 that has the exact same issue wut am i supposed to do?
  • 846 Answers
Looks like you need a new usb jack module which you can replace yourself. Here's a guide on how to disassemble a blackberry.However you will need soldering skills to replace the module. Maybe a techsavy friend can do it for you. If you want to have somebody else do itfor you go do Blackberry Repair.
Posted on Jul 19, 2010
Is it still under warenty? im sure it is, i had the same problem, i toook it back to my service provider, vodafone uk, and they replaced th ehandset for free
Posted on Jun 12, 2008
I was able to get AT&T to replace my 8800 because of the mini-usb issue-it got pushed down and became unusable, I didnt have any water damage issue but I know they checked some indicator for that issue. I was surprised that no one offers insurance for blackberrys. Big risk using them!
Posted on Nov 15, 2007
Buy an extra cx-2 battery and an external battery charger...
My USB port broke on me THREE times...the first two times it was covered by warranty and I sent it back through BELL to get replacement (refurbished) phones.
The third time it happened, it happened of course after my 1 year manufacturer warranty date...
I've been living with it like that since...but, the external battery charger is great. The only draw back is the amount of time it takes for the phone to boot-up/provision after rebooting.
Posted on Mar 30, 2009
Forget fixing the phone, just buy the power station, it is a bit pricey but it works!  Even if you do go through the warrenty, BB repair centers are from CANADA and as many of these BB's with this type of issue - it is taking up to 2 weeks to get your precious, much depended on BB back!  Get the power station and then if you really want to push data through the USB... well... just pray.
Posted on Sep 06, 2008
We are US Communications and we repair all types of blackberry issues including water damage. Please call us at (954) 390-0999 or E-Mail to [email protected]
Posted on Mar 03, 2008
SOURCE:
I can't figure out how to charge the battery. I rec'd a AC wall charger but I can't figure out where to plug the male end in on the tablet
The charger plug should plug into the mini-USB port. This is the same port for the USB cable that would connect to the computer, and in fact the tablet can be charged from the computer if the computer is on.
Mar 23, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
I lost the charger, and i can not find, one do you know where i can find a charger?
"Charging the Player
To charge the player, simply connect it to a powered USB port, or external AC adapter. If you choose to use a third party adapter, please ensure that it is 5V and between 350 and 500mA. "
i'm assuming you need a mini usb or micro usb cable? many phones charge using these...you can buy one at tons of stores. just make sure you get the right one. you can charge from your pc (with usb port) or a wall outlet, provided you purchase the correct charger.
(from )
Oct 16, 2013 | Mach Speed T2800 MP3 Player
The charging port broke of from my htc evo 4g phone.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 10, 2012 | HTC EVO 4G Smartphone
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Why will my phone not power on? The let stays solid while charging but will not power on
are you trying to charge the phone with the wall charger or the USB cable. if it is the USB cable then chk if the USB port both on the laptop and the hand held is faulty or not, then chk if the USB cable is faulty or not. if you are to charge through the wall charger then check if the charge is faulty if every thing this is fine then get chk the battery.
Aug 07, 2009 | RIM BlackBerry 8800
Blackberry 8800 will not charge on wall charger
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
May 21, 2009 | RIM BlackBerry 8800
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
RIM BlackBerry 8800 Logo
3,606 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Ekse
Vincent G
Vincent G
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
