Question about Measuring Tools & Sensors
Culligan water softener c5 error code - Measuring Tools & Sensors
BillB-SA
  • 2761 Answers
SOURCE: I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Posted on Nov 15, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
Posted on Dec 22, 2009
ftw1952
  • 10319 Answers
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Posted on Mar 06, 2010
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
Culligan Mark 100 Had code C5 Doe not work. What does code C5 mean?
A lot of people mistake the "S" as a 5. The error dispaly says "CS" which means call service. You probably have a gasket hung up and need a new seal pack.
Mar 04, 2015 | Culligan Measuring Tools & Sensors
How do i fix a code 5 error on a culligan 100 water system?
what does c5 mean? I can't get it off the digital face and had to by pass to shut off.
Aug 21, 2013 | Culligan Sediment Water Filter
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Nov 15, 2009 | Culligan Sediment Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Measuring Tools & Sensors Logo
136 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
