Question about Dell POWER SUPPLY PS-5201-5D (PS52015D) Power Supply
Dell power Supply has won't work
I have a Dell Power Suplly model number PS-5201-5D it won't work. what seems to be the problem? Thanks a lot if u can give me what will i do. Renato
    Novelist:
  • 231 Answers
Hi, all power supply's have a fuse in them, remove the power supply, open it up and study the printed circut board, you will see either a white ceramic or glass fuse attached to it. Replace this and reasemble it then re-install it into your computer and then test it. If you still have no power then you will have to replace the unit as the costs of repair are far greater than a new one. Goodluck, mistyman
Posted on Aug 30, 2007
SOURCE:
I installed PS 6351-2 power supply and now on startup, it is not getting BLUE light until you press the button a number of times, what can I do?
Hard to tell without actually testing the circuitry, I would place my bets on the button switch being intermittent. See if pressing it harder makes it work the first time.
May 04, 2015 | Dell Inspiron 530 Desktop Computer
Want to replace a power edge sc1420 power supply with a regular atx power supply has anybody done that. Think the ATX connector is the same but on the other connectors there are many blue wires and I don't...
1) Dell power supply is unique , you can never replace with another regular ATX power supply
2) Please get 2nd handed Dell power supply from the same model. try ebay
Mar 22, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
How do you jump start model dell ps-5201-1d i want to see if it works with out hook in up to the motherboard
use a multimeter or plug a fan into one of the molex connectors, flick the switch and some times the fans will twitch a little when the power supply itself is turned on.
May 28, 2010 | Dell - PS-5201-1D (PS52011D) Power Supply
OptiPlex GX520 PC Desktop: POWER SUPLLY IS OK,BUT PC CAN'T ON.SWITCH IS OK....
If you're sure that your power supply is okay and the switch is okay, but the computer won't switch on, the problem is most likely somewhere on the motherboard. What happens when you turn the computer on? Do any lights come on? Do the fans come on? Is there anything displayed on the monitor?
If you have access to another computer, try installing your power supply in that computer to make sure the problem does not lie with the power supply itself.
May 18, 2010 | Dell OptiPlex GX520 PC Desktop
No power
check your powers suplly waltage and earthing properly.change your power cable of lcd monitor.
reconect it.fix it proerly.then try u can do it.
Feb 09, 2009 | Dell E153FP 15" LCD Monitor
How do i get into a dell w5300 to change power supply?
You can remove the side panels and then remove the cover over the power supply. You'll also have to remove the fuser connections.
Jan 07, 2009 | Dell W5300N Laser Printer
A PS-5022-2DF Power Supply
When a power supply goes bad they are generally not worth repairing given the low replacement costs these days.
I have bought a lot of replacement Dell power supplies from this place over the years.
http://www.affordablesurplus.com/dell-PS-5022-2DF-0N0836-power-supply-250.asp
Remember a lot of Dell power supplies and motherboards are proprietary so you cannot use generic parts.
Aug 11, 2008 | Dell (9228C) 200-Watt Power Supply
150 W ATX Power Supply HP-150SS
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
350 people viewed this question
Ekse
Clive
Clive
