Cpu fan wont rotate - Computers & Internet
    New Friend:
  • 17 Answers
CPU fans are notorious for locking up. You can try lubricating it with a WD40 type product but this usually is only a temporary fix. The fan should have some manufacturers information on it. Try a web search for that information and that should lead you to a retailer who can sell you an exact replacement fan.
Posted on Jul 26, 2013
Dell inspiron D610 fan wont turn on
New cpu heatsinks use water in sealed tubing, and can cool for a long while. Idling computer may not need more cooling.
Mar 15, 2012 | Dell Lattitude D610
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
511-cpu fan not detected
are you the one opening your desktop computer?
If you are, check your cpu-fan connector pin if its properly connected to the motherboard
If not
check if your cpu fan are working if it didn't rotate replace it with a new one
Jul 26, 2011 | Compaq (283983-001) Motherboard
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
I cant remove my fan its an intel D34223-001
Intel D34223-001 is fan and Heatsink assembly for Intel Socket 775. Following are the videos about removing and installing this fan
REMOVING FANINSTALLING FAN
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 29, 2011 | Intel (D34223001) CPU Heatsink Fan
Sir, my sony vgn cs100E laptop fan is not working, i keep my laptop very clean, but now when i start windows the laptop automatically shutdown after 3 min processing. Fan is not working. what should i do?...
Hello Faiz
OK, the thing is, if the fan is not rotating at all, you will need to replace it. The problem related to the computer shutting down, is the fact that the CPU overheats, and then shuts down the computer to protect the system components.
SO, if the fan actually rotates, you will need to clean the fan from all the dust particles collected on it. If the fan does not rotate at all, you will need to replace the broken fan.
Hope this can be of help.
Kind regards
Andrea
Nov 28, 2010 | Sony CPU FAN CPU Fan
I'm hearing some unwanted sound after I turned-on my acer netbook. Also the monitor is keeping on blinking when the sound comes out. It's like a sound of a small blower or a small dynamo. I'm afraid that...
Hello
OK, now, the only components in your computer which actually rotates which can explain the the sound you are hearing is either the CPU fan or the CD/DVD rom or the Hard Drive.
You can test if it is the CD/DVD rom by opening your CD/DVD rom while starting the computer up. If the sound persists, it is most probably your CPU fan.
The reason for your CPU fan to rotate at high speeds is most likely the result of the CPU itself not getting the sufficient cooling, hence the fan needs to rotate faster.
I would suggest that you have a look into the matter if it is your CPU fan, because this might cause your CPU to become faulty when it overheats. You can open up the unit and use some compressed air to get rid of all the unwanted dust particles on the CPU heat sink and fan.
Fell free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 22, 2010 | Acer Aspire One PC Notebook
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
