Question about Compaq Computers & Internet
Fan not coming - Compaq Computers & Internet
    Brigadier General:
  • Compaq Master
  • 3,400 Answers
OREL,YOU MUST BE MOORE DETAILED.
Posted on Jul 26, 2013
Cooling fan not coming on I can make it come on by turning A/C on the other thing is I can pull the fuse out and the fans come on put fuse back in the fan cuts off please help
Hi Matt ,
In this case if after pulling fuse fan get start it means all the wiring, relay and fan is fine you just need to replace the thermostat/Tempratue sensor sensor, it comes on the radiator.
Thanks
Yogesh Mule
Jan 11, 2015 | Cars & Trucks
I have a 2004 chevy malibu which overheats due to the fans not coming on..i checked the actuall fans and they do come on..checked relays and coolant temp sitch and its good
if your fans come on with ac on,then your fans are OK ,coolant temp sensor, is bad,need to be changed,(that is how fan relay get it's ground,or it gets direct ground when you turn the AC on)
so if it comes on with AC on,your fans and relays are good
you can run the car with ac on till you fix the problem(it only hurts your gas millage)
Nov 11, 2013 | 2004 Chevrolet Malibu
I need help how to make the dimmer works fro my fan westinghouse 52'comet. i have the blue wire coming for fan connected to black coming from wall,and the white coming from fan connected to red coming from...
How are they connected in ceiling? If the blue wire from fan is connected to the red wire then the light wire from the switch would be the same. Since you have two blacks coming from the wall you'll have to connect the other wires until it's correct.
Jul 31, 2013 | Dryers
Vornado fan repair
i need help wit my westinghouse 52' ceiling fan. i have the lights wrking and the fan, but the dimmer wont work. i have the blue coming from fan connected the black coming from wall,and the white coming from fan connected to red coming from wall,then black coming from fan connected to another red coming from wall. now i need help how to make the dimmer work, is my connection wrong?
Jul 28, 2013 | Dryers
Vauxhall corsa 1.2, cooling fan not coming on
Radiator fan switch situated on the rad tank some have 2 of them if it has aircon .check power 12v at the swich .bridge the power and earth wires and the fan should come on .If it comes on the problem can be two things blocked rad or faulty switch .if the fan does not come on the fan motor is faulty.
May 23, 2012 | Cars & Trucks
Replaced the radiator, and the fan relay sensor, fuse is fine and fans work but the fans will not turn on when the car starts
Radiator fan will not come on right away, only with a/c on, fan should come on when temp. is about 1/2 way up, or 220 deg., if fan is not coming on at all with a/c off, check your coolant temp. sensor, sits close to your thermostat, if you unplug it and fan comes on, replace sensor.
Jul 07, 2010 | 2002 Chrysler Town & Country
Laptop getting unusually hot in operation
Re: "the FAN runs only when the booting is being done.but it stops as soon as the booting is completed".
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
Here is the software to control your fan and temp state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
May 05, 2009 | Acer Computers & Internet
A/c fan not working
are you saying the fan never comes on or just doesn't come on when you're watching it? most fans come on when the radiator coolant reaches a certain temp, then flips a relay to send power to the fan.
if the car is warmed up and the fan is not coming on (or if the A/C is selected on and fan doesn't come on), i would suspect the relay since you already proved separate power to the fan does make it work.
good luck
Jan 27, 2009 | 1997 BMW 318
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
Computers & Internet Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
