Bluesky washing machine need know spin speed blf 518
After washing machine gives fault indication by two flashing leds on the frontpanel. Water stays in machine, door can be opened with flooding as a result. Can someone give me advise?
SOURCE: Upon closer inspection it DOES NOT WORK....WTF????
REPLACE TIMER CONTROL BOARD
Posted on Jan 31, 2008
barkencoa
  • 3463 Answers
SOURCE: the door lock led stays flashing even after machine is turned off
Control module probably faulty, this could have failed due to motor problem check for worn carbon brushes in motor.
Posted on Nov 18, 2008
Online-Tech
  • 51 Answers
SOURCE: whirlpool awo 3751/5 will not spin
There is a locking coupler on the Whirlpool washing machines that locks when it kicks into spinning cycle. I am guessing here, but if you try and run it without any clothes in it, it will probably spin. It will be slow starting, but it will probably spin.
The coupler is located down by the motor and is three pieces. They made it out of plastic, and while it typically holds up very well, they do break. I will try to look up the part # you need to fix it. (assuming this is your problem)
Thank you for contacting www.Fixya.com
Posted on Jul 29, 2009
  • 105 Answers
SOURCE: I have got Indesit WIXL 123 washing machine. Until
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Posted on Nov 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: I HAVE A BLUESKY WASHING MACHINE.(MODEL BLF 1011
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Can you tell the best program for a mixed clothes wash on a bluesky blf 1011
Sorry there is NO BEST just do a normal wash .depending on how dirty the stuff is of course . fixya can not determine what your stuff looks like
Sep 26, 2017 | Washing Machines
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Bluesky BLF 1060X user manual
can you take a picture
front ,side and the back plus may be the filter
Feb 08, 2014 | Washing Machines
Manual de Bluesky BLF 518
Not a solution but a follow on question?
How do I remove the door hinge.
It has broken in 2 parts. The part attached to the door I can remove. The part attached to the actual Washing Machine, I have removed the 2 obvious screws from the outside , but it will not come away.
Looking inside I cannot clearly see any screws thru from behind!,
But its not easy to see !
Any Advice tips/hints etc Greatly Appreciated
Aug 18, 2012 | Washing Machines
Fault 9 come on
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
My wf310 1100 spin will not do a high speed spin
hi, there may be not enough water draining out on the last cycle before it spins so i'd give the pump a good luck over also check the filter if it has 1, and check the drain hose. the other fault could be the module control board this controls the motor speed hope it helps
regards
shaun
Nov 27, 2011 | Washing Machines
Will not spin
Some of the Wash Progress LEDs flash when the machine stops due to a fault. The 8 Wash Progress LEDs stands for the binary digits and by indicating the digits, the fault code number is determined. The fault code can be shown by activating Diagnostic Mode if none of the Wash Progress LEDs are lit.
Turn machine OFF on the control panel then hold down the Water Temp Down button and press the POWER button until the machine gives 2 short beeps and lights up. Release buttons and you are in Diagnostic mode. Press the Spin Speed Up button 3 times until the Hold and Slow LEDs are lit. Write down the LEDs which are lit across the Wash Progress LEDs and post it back.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting the solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding your concern stated herein.
Sep 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
