Question about Canon ImageRunner 2270 | IR2270 |
Canon ir2270 booting problem
When machine start screen show wait... but machine not start. After RAM change, Hard Disk change but machine was not start. Why problem in machine
  • Canon Master
  • 27,725 Answers
If this is a desktop computer ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Jul 30, 2013
Canon iR2270 cause E602-0001. Hard Disk check mode (holding 1 and 9 when switching on) can't fix problem - machine enters in "download mode". Help me please!
some times it does not work and u have to need replace ur hard disk
Or u can try * 28 holding when u start the machine and also *19
Jan 14, 2013 | Canon ImageRunner 2270 | IR2270 |
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
How to install sata driver while i setuping xp on it.....now blue screen is showing telling that to reboot pc or do chkdsk
for blue screen : just change slot of ram or change ram.. for sata driver : just insert partitionmagic disk and partition your hdd.. otherwise clean your hard disk using any hdd utility or Hiren's Boot CD
Aug 12, 2011 | Compaq Presario Notebook
My desktop pc cannot boot again, it keeps on showing disk read error.
if its showing disk read error then possibly there is some problem with your hard drive or RAM. there are more chances that you have to change your hard drive.
but you can try one thing just boot the computer using a bootable windows disk and try to full format the hard disk and then install the OS. it should help.
but if there are bad sectors in your hard disk then it seems that you have to change your HD.
Jan 06, 2011 | Dell Computers & Internet
When I star up my computer Toshiba a135-S4427, it boots up and then goes to a blank black screen. I am unable to get to the log in screen. It just sits there, I can hear the processors and the fans...
Seems a problem with RAM. Remove your RAM from the slot and start the PC, long beep sounds are audible, then the RAM is OK, else time to buy a new RAM/ memory.
Else Try for the Hard Disk, Check the Hard disk in your's friend's PC, remove his Hard disk and insert yours, if the same problem arises, change the Hard Disk or if nothing happens, system boots,
it seems a problem with motherboard, Get it repaired by a expert or buy a new one.this will work.
Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Toshiba Satellite A135-S4427 Notebook
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Canon ImageRunner 2270 | IR2270 | Logo
78 people viewed this question
old marine
old marine
