Can i listen to police scanner
SOURCE: i'm just looking for the police frequinecs that i can listen to on my home scanner
Lil p, hi, I'll see if I can solve your problem. If you are looking for freq's for around your area, go here and click on your country-state-county and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you do need a 10 code list for your area, go here,and click on your state.
http://www.nat-com.org/radio.htm
I hope this helps you out with what you were looking for, let us know.. Mechanic
SOURCE: trying to find police codes so i can listen to the police
SOURCE: programming
No problem!
First if you don't have an owner's manual you can download a copy free HERE
Be sure to read all of it...it's got great info to get you comfortable with all the controls of your scanner.
Secondly you'll need local radio frequencies for your area.
Do a google.com search enter "radio frequencies" and also the name of your city, county and state.
You'll find people may have posted lists of frequencies for your area.
Print out the lists and then by following the step by steps in the owner's manual, enter each frequency into your scanner .
Once you've got them entered... you'll be ready to scan!
For understanding the 10-code language used, do a google search for "10-codes" and you should be able to find a list of definitions... They'll also use alot of local abreviations for street names and locations and those will be understood more as you listen to your local calls for a while.
good luck and have fun...and be safe.
k
SOURCE: Can you listen to a police frequency if it's
You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
