Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
"Cover Is Not Open" And The "Lens Cover" Is Open...
Both LCD/Viewfinder is working great on the "Sony Handycam DCR-HC21" but this message comes on in the middle of the screen with the message "Cover Is Not Open"; whenever it's on "Standby" or "Rec" and the "Lens Cover" is already open! Sometimes, I tried a little method and close the "Lens Cover" to fool it, it works fine when it close with the message "Cover Is Not Open" and it takes a few seconds before fading out the message, somehow that method didn't quite work out! The message with "Cover Is Not Open" always fades in and out, sometimes stays on 20 or 30 second and fades out..other times if we can't find any solution for the moment, we just continue to "Rec" our families video and try to ignore that message as much as possible for the meantime... We all appreciate yours and others people effort and ideals for trying to help us and others out of these troubleshooting problems and solving techniques, thanks again... I really hope ya'll can find a solution to our problems, thanks again... <><><><><><><><><><><><><><><><><><><><> FixYa, ya'll had solved my sister camera problem: Sony Cyber-Shot DSC-W7 Digital Camera had a glitch... Shutter stay open, even though she turns it off and the lens doesn't close, there's was this message saying turn it off and on, it will set it self back; but it doesn't anything of that! I read the result solution to the camera's problem was the shutter was stuck open; but I had tried several my method by tapping the lens on each side of it on my mouse pad, turn it on and off, no result! Then I tried another method by applying a little pressure on the lens by pushing it softly on my computer mouse pad, and turning it on and off; eventually, after a few tries, it loosen the shutters and lens from opening and closing it... Now, it's purring like a cat, it works quite well, now my sister thanks me for a great job I had done; but I told my families about your computer website called "FixYa" - it gives out a whole lot of in/outputs of troubleshooting, repairs, post a problem and they will try there very best to find a solution to solve that mysteries on electronic things we all have problems with, thank you very much for that helpful hints! Ka~Chow
  • jepoy29 Jun 19, 2008
    My Sony DSC F828 will say "cover is open" whenever you grip tightly on the right handle. I guess the cover that they where talking about is the cover where you open to get the memory card. how do I fix this?
  • 169 Answers
The lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Posted on Sep 02, 2007
The message will not appear if you open the lens cover before you turn on the recorder.
Posted on Sep 26, 2007
I put several tiny layers of tape on the silver contact to close the distance between it and the door. Works fine on my F828
Posted on Sep 05, 2008
Well, I wasn't about to spend more money to repair the "Cover Is Closed" message that was appearing on my LCD and viewfinder of my Handycam DCR-H42. So I just got out the ol' Dustbuster aerosol, blasted the lens cover switch and the lens' and shutter surrounding area. Worked the switch back and forth rapidly a coupla times and the message disappeared. That may have cleared the oxidation and/or dirt on the switch contacts.
Posted on May 29, 2008
  • Scott Dec 13, 2010
    awesome!!!! thanks so much!!
White LCD Screen on Sony Handycam DCR-HC21
check whether can see the picture through vew finder,if yes replace srtip wire from main board to lcd bord
Jan 10, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Nothing in viewfinder or on screen
Same thing happened to me. Seems to be 'common' although Sony says they have no recall on the CCD. Look around the forum and you will find others with the same problem.
May 24, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Mini camcorder DCR-HC21 problem with LCD and viewfinder. need help ASAP!!
i have the same problem,i opened the camera, i have taken out the flexible cable, its broken at the hinge...it looks like a bad design of the cable is the reason.
the cable is 1cm in width and at one point when it passes through the
hinge the cable is split into two with .5cm width each. one cable is cut at the pt where it enters the hinge, this cable is stretched to fit into the hinge, guess thats why it broke so soon...
It would be great if some1 can guide on from where and how to get this cable..
Anand
Jan 14, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony handycam lcd sez 'cover not open'
maybe you have the wrong type of tape or check and change all of the settings to normal
Jul 01, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
2,029 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
