Duracell bluetooth DU2101 will not turn on
So I see 2 switches on it, a square one on the main side with I think an light-up indicator plus a slice-like switch on the top. (Sorry I am not very tech savvy and not using the right words.) Neither will cause this bluetooth to turn on. I think the square switch indicator is supposed to light up and if it does not light up, is it not on? So...it won't light up. What is wrong with it and what to do to turn it on? Is there a battery to change somewhere?
lorenzo_most
  • 60 Answers
SOURCE: wireless communication switch
Try to go under the BIOS and check if it's turned off
Posted on Apr 01, 2009
  • 145 Answers
SOURCE: AC & Rear wiper switch button indicator lights blink
The procedure for re-setting the HVAC control panel on a 1998 Dodge Grand Caravan follows:
With ignition on but not running
1. turn knob to air vents
2. turn fan knob to ON
3. temperature setting on COLD (2X) {I have dual temp controls}
4. hold top(rear wiper) and bottom (rear wiper with wash) buttons pressing down together until all the buttons cycle through (this will require 1 to 2 minutes of continuous pressing)
I learned this from a very helpful local Dodge service adviser
Posted on May 15, 2009
  • 157 Answers
SOURCE: DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Posted on Jun 19, 2009
msnseb
  • 88 Answers
SOURCE: Dell Precision M6300
There is a bluetooth device installed, but no driver, or updated driver to run it!
Posted on Jul 06, 2009
SOURCE: Dell Inspiron e1405 bluetooth disabled
If it doesn't show in device manager than it doesn't have a driver, you will have to reinstall, go to the link below, download and install, ALL, the correct files for your version BT, Bluetooth files there, that should fix it.
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_E1405&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Posted on Feb 26, 2010
Tip
Wiring Diagram Kawasaki GPZ 750
Kawasaki GPZ750 (ZX750) Turbo North American models.<br /><br /><img src="suzman_10.JPG" /><br /><br />1 - Right turn <br />2 - High beam<br />3 - Warning light<br />4 - Headlight fail<br />5 - Neutral<br />6 - Left turn<br />7 - Boost Guage <br />8 - Tach light<br />9 - Tach/volt switch<br />10 + 11 - Speedo lights<br />12 + 13 - Illum. lights<br />14 - Spare connectors<br />15 - LCD + warnig lights<br />15 + 16 - LCD illum<br />17 - RF indicator<br />18 - Horns<br />19 - Headlamp<br />21 - LF indicator<br />22 - Reserve lighting unit<br />23 - Hazard switch<br />24 - Indicator switch<br />25 - Horn switch<br />26 - Dimmer switch<br />27 - Starter lockout switch<br />28 - Neutral switch<br />29 - Side stand switch<br />31 - Oil pressure switch<br />32 - Alternator<br />33 - Regulator<br />34 - Solenoid<br />35 - Starter<br />36 - Battery<br />37 - Junction box<br />38 - LR Indicator<br />39 - Stop/tail lamps<br />40 - Stop/tail lamps<br />41 - RR Indicator<br />42 - Injectors<br />43 - Engine temp switch<br />44 - Boost sensor<br />45 - Fuel pump<br />46 - Air temp sensor<br />47 - Throttle sensor<br />48 - Main pump relay<br />49 - Fuel injection control unit<br />50 - Rear brake switch<br />51 - Pick-up coils<br />52 - Ignition control unit<br />53 - Coils<br />54 - Spark plugs<br />55 - Fuel level sensor<br />56 - Front brake switch<br />57 - Starter/engine stop<br />58 - Ignition<br />
on Nov 22, 2010 | Motorcycles
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
key (for about 5 seconds) until the
green indicator light starts to flash
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
and connect the headset to your
phone. In some phones, you may
need to make the connection
separately after pairing.
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
When the headset is connected to
your phone and is ready for use, the
green indicator light flashes slowly
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Laptop is turned off but the lights are still on
Can you describe the symbols that are next to the lights that are still lit?
If your laptop is still attached to mains power (ie your power pack that feeds DC voltage to your laptop) the battery pack may be still charging (indicated by a light) The battery pack is internal to your laptop and this powers your laptop when the power pack is not connected to mains.
Try disconnecting your mains power and see if a light goes off. If it does then that light is the light which indicates charging is in progress.
Other lights that are typical to laptops are:
a. hard drive activity (usually lights when the hard drive is being used) Usually has an adjacent symbol which looks like a metal can or cylinder.
b. bluetooth (wireless connection to other bluetooth devices such as cell phones, other bluetooth devices such as another computer) Adjacent symbol looks like two triangles side by side.
c. sleep (usually lit when your laptop goes to sleep and saving power) This may be covered by the power on lamp mentioned below, and the power light may flash to indicate the laptop is in sleep mode to save battery power.
d. power on (lights when your laptop is ON)
e. battery charging (as described above). There is often a symbol adjacent to this light that looks like a small battery.
Good luck,
Steve (Melb, Australia)
May 12, 2010 | Toshiba Computers & Internet
VFR800-2 Bike cuts out when lights,indicators or pass flash
I don't think you have a short. It sounds like the earth cable is broken somewhere and is arcing when you start drawing a bit of current.
Aug 17, 2009 | 2002 Honda VFR 800
My duracell crank light 3 in 1 is not working properly. I rotated crank handle for about a minute or 2 long,thinking that charging would be enough and led torch will light for few minutes during power cut...
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
Jun 27, 2009 | Duracell Crank Light 3 In 1, 3 Led...
Indicators/flashers
Check your wiring for continuity. Mine did the same on the Fatboy - found a broken return wire by the right Handlebar switch when I opened up the switch gear housing on the bars. Bit of solder, heatshrink and good as new! (my problem light was on the right side so check the left side on your first - was a white wire with orange stripe I think, should be easily visible from the indicator switch inside). All the other lights worked fine. Maybe an earthing problem?
Oct 31, 2007 | Harley Davidson Harley-Davidson Motorcycle...
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
