Question about Panasonic Heating & Cooling
E2 error air conditioner - Panasonic Heating & Cooling
  • RahulNXG
    RahulNXG Jun 27, 2016
    SENSOR PROBLEM PCB CHECK and replace,Coil Temp Sensor Faulty/ cable cut
SOURCE: e2 CODE ON SUNBEAM SCK14200DR
I just fixed this on mine one minute ago.
Take off the front panel.
You will see a black wire held onto the heat fins by a plastic clip.
This is the thermocouple that measures temperature.
Mine became unplugged from the circuit board and plugging it back in fixed the problem.
The wire goes into a steel box.
take off the screws on the bottom of the box, grab it by the lowed left corner and bend the metal up as far as you can.
The wire plugs into a small white connector on the circuit board.
plug it back in, bend the metal back down, screw it in, replace the cover, and you should be good to go.
-Alexander W MacFarlane IV Ph.D.
Posted on Jun 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
SOURCE: I have an E2 error message on my air conditioner.
It might be a faulty thermestat, I don't know if your case is the same as mine but whenever my edgestar gets around or above 78 degrees it brings up the E2 code but as soon as it drops back below 78 the E2 code goes away and all the normal functions start working again.
Posted on Sep 02, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
I have an E2 error code, how do I resolve this
I simply disconnected my battery to reset the thermostat and my E2 problem fixed itself...
Jun 07, 2011 | Dometic Rooftop RV Air Conditioner
Error code E1 and E2
E1 error - Indoor room temp sensor defective. Replace it.
E2 error - Indoor coil sensor open. Replace it.
Hope helps.
May 03, 2011 | Sunbeam SCA102RPC1 Portable Air...
I have an E2 error message on my air conditioner. It has stopped working and resetting it doesn't help.
means you have less that 24 volts to thermostat check transformer or wireing to tstat
Aug 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
