Panasonic Plasma TH-42PA20 picture reset issue
My Panasonic Plasma TH-42PA20 seems to lose colour and ends up with a basic green tinge. Can you help, please? I've had the set from new and, as a pensioner, can't afford a new one.
SOURCE: The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
My plasma tv ONLY show green light for maximum of 2 seconds and off Itself again which means NO PICTURE, NO SOUND !
Posted on Jan 27, 2008
tvguy171
  • 106 Answers
SOURCE: Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Posted on Nov 26, 2008
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
  • 1894 Answers
was that capacitor damaged?
Posted on Jan 11, 2008
Raditronic
  • 196 Answers
SOURCE: Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Posted on Dec 20, 2008
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Sep 13, 2011 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Jan 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
The color on my tv has gone crazy. There's either a blue tinge or a yellow tinge when I adjust the colour (so either people look like they are faintly related to a smurf or have scurvy!!). I am also...
I would suggest to unplug the TV from the AC power outlet first, wait a couple of minutes to plug it back in. If that does not work, the main board is defective since is not providing proper video info to the main digital controller board (D board). The Main board part number is: TNPH0721AJS or TNPH0721ADS. If you need to verify the main board part number, you will need to remove the back cover of your plasma to check it out.
Let me know if you require further assistance.
Nov 27, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Th-50px70b
when doe s this happen on hd tv bad signal on antenna will cus ethat to happen heavey comprsed dvd bunred will also do it may need better antenna ok
Oct 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Panasonic th-42pa20 plasma 42 inch tv
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
