Oki c310dn error 990 - Office Equipment & Supplies
Oki c321dn 'service call 990:error'
Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Aug 14, 2014 | Office Equipment & Supplies
C310DN K toner not installed
replace with correct Original manufacturer toner cartridge.
Jan 16, 2014 | OKI C Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
My ricoh 305on is displaying error 990. I have
change the ink collector located in the rear of the machine
Mar 11, 2009 | Ricoh Aficio GX3050 GelSprinter
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
234 people viewed this question
jasbo
jasbo
