Question about ASUS Computers & Internet
Not power up in asus x55a laptop, battery has been fully charged and ac adapter connected and not power up my laptop?
map9966
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Posted on Jun 21, 2008
SOURCE: Toshiba Satellite M65-S909 laptop will not start
I had the same thing happen when I was fiddling with the 9092 monitor refresh rate. The video circuit had a few episodes of video switching and the system shut down never to wake again. I figured it was connected to this circuit but I couldn't fix it. I bought a new one but I haven't tried to recreate the problem:-|
Posted on Aug 30, 2008
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 1481 Answers
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Posted on Dec 29, 2009
Yam, try taking the battery out, reinstall it, check laptop properly connected to power supply and properly plugged in. Turn on the switch making sure power light is on. If still no power, get it checked.
Jul 26, 2013 | ASUS Computers & Internet
When your Laptop batteries are fully charged is it a good idea to keep the adapter on?
Remove the adapter when the battery is fully charged, you do not need to have the adapter connected all the time.
Sep 11, 2012 | ASUS Eee Computers & Internet
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
Noise from dc adapter asus a6rp
A high frequency whistling sound may indicate a capacitor in the AC power adapter is beginning to fail, but it will often whistle while it works for years to come. You don't have to replace the AC power adapter just because you can hear it, unless it gets worse and worse over time or it gives you a headache. Because AC adapters employ switching mode technology, they are more likely to make noise when the battery is fully charged and the laptop is turned off. AC adapter bricks are usually glued shut and aren't designed for consumer repairs, so unless you have solid electronic troubleshooting skills and a source for parts, it's a question of living with it or replacing it outright.
Oct 22, 2010 | ASUS A6Rp-AP067A Notebook
Why i cannot switch on the laptop using battery?
Your Battery is most likely bad. Try the following connect the AC adapter and check if the battery indicator is blinking amber continously. If it is replace the battery. Allow the AC adapter connected to Power and the laptop for about 15 minutes remove the AC adapter from the Laptop and see if the system remains on. If it does, allow the battery to be fully charged and the laptop will power with the Battery.
Apr 16, 2010 | Lenovo ThinkPad SL400 Notebook
Asus w3j orange led battery light keeps flashing, and the lappy doesnt turn on? This occures while running both through the battery alone, and then with only the AC adapter connected. Do you guys have any...
This seems to be a issue with the AC adapter. Its not driving enough power to the laptop and neither charging the laptops battery. Try using a different adapter.
If the problem still exists, Then its to do with the internal power supply setup inside the laptop and probably you need to rip the laptop apart and check the power chipset.
Feb 22, 2009 | ASUS W3J PC Notebook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
