Question about Ovens
HOW TO CHANGE THE THERMOSTAT IN A NEFF B1421 OVEN
SOURCE: neff b1421 single oven
my oven is not reaching the required temprature what could the cause be please
Posted on Oct 15, 2008
barkencoa
  • 3463 Answers
SOURCE: neff b1421
Replacing the door hinges is the only solution to this problem.
Posted on Dec 07, 2008
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
2coolrick
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
barkencoa
  • 3463 Answers
SOURCE: neff B1421 not heating up??? When we put on the
Hi.
If it is a fan assisted oven and the fan is working, then it is more than likely to be the oven element that is faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Aug 16, 2010
Why does the thermostat swtch off but the oven is not hot?
because its gone, or the connection to the ovens PCD board has been lost.
Sep 06, 2014 | Neff B1421 Electric Single Oven
I can't remove the backplate off my Neff B1421 oven
its a tamper proof screw at torx 20 size.dont undo with a phillips tool will ruin the heads and never get them out.
Mar 05, 2014 | Neff B1421 Electric Single Oven
Neff B1421 not heating up??? When we put on the oven- it does not heat up.
Hi.
Aug 16, 2010 | Neff B1421 Electric Single Oven
My Oven gets hot only up to 180o. Will it cost me a lot to get it seen to?
when the oven heats top this temp and no higher the oven thermostat needs to be changed out. appx. a 30-40 dollar item.
Jun 20, 2010 | Neff B1421 Electric Single Oven
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Neff b1421
Sep 29, 2008 | Neff B1421 Electric Single Oven
Neff b1421 single oven
I suspect that the thermostat has failed
Aug 07, 2008 | Neff B1421 Electric Single Oven
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
