LG Intellowasher 7.5kg WD-1223FB error code OE
My LG Intellowasher 7.5kg WD-1223FB front loading washing machine is displaying an error code of OE on the display screen. What does this mean?
2 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: My LG intellowasher 7,5kg WD-
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
Dec 25, 2010 | Washing Machines
The washer is displaying an OE. How do I fix this?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
OE Error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Oct 14, 2009 | LG WM-2277HW Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
