Question about Thermador Ovens
Thermador F15 error code
Have a Kenmore(Thermador) double oven, started getting F15 Error Code. Replaced the control board, walked into my house and the Oven was on, it actually had turned itself on! and was beeping and flashing F15 again. I now have the circuit breakers off so this Twilight Zone Oven will not burn down the house. I contacted Sears, now to the FTC.
jumptrout51
  • 3361 Answers
SOURCE: F1 error code plus constantly beeps and Oven won't shut off
ERC is bad and must be replaced.
(The Clock).
Posted on Apr 11, 2009
plnolte
  • 62 Answers
SOURCE: My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
Posted on May 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
reyjoshua07
  • 1157 Answers
SOURCE: I HAVE A WHIRLPOOL DOUBLE
Hi Pwaldo,
If you're experiencing error E6 F2 it might caused by faulty control board or control panel. Here are some ways to check this error, you can just assemble the control panel back or just unplug and replug the keypad ribbon. You could also try to do the following steps below for additional troubleshooting.
1. Disconnect the Oven from the power outlet ( remove the power from the oven ).
2. Please open the control panel then unplug the key pad ribbon from the control board.
3. Now assemble the control panel back then plug the oven to the power outlet then try powering it on.
--> please wait for few hours and observe the machine.
4. If you still have the same problem like the error E6 F2, you need to replace the control board.
- you may try to search on this part number for the control board AP3595759.
--> If you noticed that error did not show up, you need to replace the control panel ( the keypad comes as a control panel assembly ).
- please try to search for this part number for the control panel AP3131755.
- you may also contact the manufacturer to consult the part numbers.
Hope it may helps.
Thank you for using FixYa.
Posted on Mar 10, 2011
  • 794 Answers
SOURCE: Thermador Model C302 Convection Oven
Hi alatfios,
This error F24 and the beeping sound is unfortunately because of a bad touchpad. The error code F24 means that the key has been stuck for longer than 120 seconds. The beeping sound that you are getting means hte button is opening and closing. Heat will cause buttons to stick sometimes. When you warm your oven up it expands the buttons and makes it so a button is being held down so you can't push any more to turn it back on. The touchpad is the glass assembly on the front. You can purchase it online and that is the only part you need. Kindly click here to purchase.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 16, 2011
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
Where can i find a relay board #492069 for thermador model SCD302TP?
try having it rebuilt at core centric solutions dot com. they bring new life to most old electronics.
Feb 09, 2013 | Thermador SC302T Electric Double Oven
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
