SOURCE: no prende se escuha que
bueno, trata de llevarlo a un mecanico porque ese problema es delicado
SOURCE: No enciende tv. La luz
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
SOURCE: luz roja intermitente en piloto
La soluci?n no es exactamente para este modelo, pero si tiene el IC 2001 te puede servir.
Conecta a masa las patas 81 y 82 del IC2001 durante unos 15 segundos.
A ver si se te soluciona.
Saludos.
