Repair Marantz HD 440 speakers - Audio Players & Recorders
I have a Marantz sr 870 that was working fine when last used. It has been sitting a few years. I now have no output to the speakers or to the headphones. Mute is not on. Please help?
There is a repair manual http://www.manualsparadise.com/service-repair-manuals/Marantz/SR870/RWSPFM-63663893-1
I cannot speak to the company that sells its reputation. The issue is most likely due to the protection circuit in the final audio section. Most use a relay to disconnect the speakers in the event of an overcurrent condition. The relay can fail for a number of reasons.
Dec 02, 2016 | Marantz Audio Players & Recorders
How to reset marantz sr4001 from protect mode?
Protect mode comes into play when there is a problem with the speakers or amplifier First check all the speakers for opens or shorts If they are fine you don't reset it you repair the receiver.
Aug 07, 2014 | Marantz Audio Players & Recorders
Marantz pm 6004 blikining red power standby
Are the speakers connected?
If so , you have an output DC voltage issue ( typically outputs dont want to see more than 100mV DC going to the speakers. If that happens , the Protect circuit will kick in. Find a repair tech in your area because I think this amp is worth fixing
May 21, 2014 | Marantz Audio Players & Recorders
Where i can get an marantz pm493 amp volume knob also on the amp bass trible is now working and only 1 side speaker power is working any idea what is wrong..
you can get the know right from the dealer at this link http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx as far as the one speaker working, switch the speakers to make sure its the unit and not the speaker box, if that doesn't help you probably have a blown output in the unit itself,, since its a Marantz Its worth the cost of having it repaired,, as with all High end receivers or amps, Be sure the unit is in the off position before you attach or disconnect any speakers ,, if they short out,, our gonna blow the output
May 21, 2011 | Audio Players & Recorders
What kind of speaker watts should be ok to marantz pm74d?..i want to know to make the sounds make better...
Hi,to know what watts to use for marantz pm74d, first you will need to know the watts of marantz pm74d for you to be able to know the watts of the speaker you will want to use for marantz pm74d.
You make sure the watts of the marantz pm74d you want to use for the speakers are not bigger the watt of the marantz pm74d,
eg, marantz pm74d----150 watts
speakers depending on the numbers of speakers your using 60 watts.
So if you are using one speaker of 60 watts and your using more than one, add all speaker watts and divide the speaker watts by the marantz pm74d watts, the weight on the marantz pm74d will be too much to handle too much speakers.
Make sure the marantz pm74d watts is high enough to carry the speaker you want to use.It helps you determine the quality of sound you want to hear..
Thanks for using fixya........
Jan 06, 2011 | Audio Players & Recorders
I have Imperial 4 speakers circa 1971. One of the woofers popped the center black cap and is now fuzzy at moderate bass levels. Can I get a replacement speaker somewhere? Thx, Rich
I do most of my vintage audio shopping on eBay.
You could probably get a whole pair of them for less than sourcing the individual woofer.
http://cgi.ebay.com/Marantz-Imperial-IV-Speakers-model-4-nice-cond-/290510404317?pt=Speakers_Subwoofers&hash=item43a3c4fadd
Ends Dec 15, 201019:15:17 PST - Right now at $15.00 with $15.61 shipping.
Or maybe you just need to refoam them....
http://www.simplyspeakers.com/marantz-speaker-foam-edge-repair-kit-fsk-3.html
At $26.00 for this kit, I'd opt for whole speakers.
Dec 08, 2010 | Marantz Audio Players & Recorders
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
Marantz support question
This is the problem with computerized stereo's. The old analog stuff we could fix forever, but many of these digital problems, only the maker has the tools to repair. Feel fortunate that yours will even offer you support, even though expensive.
Good luck.
Jan 28, 2008 | Marantz SR-7200 Receiver
 Grubhead
Grubhead
