Question about Canon Office Equipment & Supplies
Power supply circuit diagram
No power b/c of 110va is normal the customer give 220v that is why is but what i need out put which one is 32v and 24v i can't
3 Suggested Answers
  • 217 Answers
SOURCE: changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
Posted on Apr 05, 2010
SOURCE: hp psc 1315 all-in-one inkjet
nais ko pong magkaron ng installer ng hp psc 1315 all in one para magamit ang aming printer. nawala kase ang installer nmin.
Posted on Feb 10, 2011
I need a contactor or relay with a 32 v coil and can handle minimum 40 amp
many shops and stores provide this.. if you talk to a local elecrician i am sure he is able to obtain it for you, or you can do a simple google search witch will give you many alternatives. following are a few i found by a quick search
Solid State Relay 40A 3 32V DC Input
60A AGT SSR Solid State Relay 3 32V DC 24 380V AC 24V 380VDC Newegg com
Aliexpress com Buy 1pcs SSR 100DA 100A Solid State Relay Module 3 32V DC...
if none of these fit your requirement. there are cheap and easy ways to drop the voltage across the coil. so you may use a 24v version if you do
Apr 10, 2017 | Dehumidifiers
How can I wire a 220volts sire to a fire control panel which has a 24volts bell output?
You will need to purchase a relay capable of handling 220v with a minimum of 5A. Wire the 24v bell output across the COIL of the relay, then wire the relay commutator connections to switch power, so that when the relay receives 24v, it switches supply power to the 220v siren.
May 07, 2015 | Heating & Cooling
REPER AC ADAPTER K30263
K30263 Adapter..... is REPER "REPAIR"
CANON K30263 AC ADAPTER 32VDC 0.9A 24V Used POWER SUPPLY PIXMA M
$59.99
Condition : Used
Content : One Adapter only Manufacturer: CANON
Model Number: K30263
Part Number: QK1-2228-000-DB01-01
> Input Voltage: 120-240V~ 0.9A 50/60Hz
Output:
32V === 0.9A
24V === 0.5A
24V === 0.03A
Output Connector Type : 2 rectangle White Flat
1 x 2Pin, 1 x 7Pin [ • • ] [ • • • • • • • ]
Dimension: 17 x 10.5 x 7 cm approx.
Weight: 310 grams approx.
Compatible with: Canon Pixma MP830 Printer K1027 K10270 QC1-9029-DB01-01
http://azsurplus.com/index.php?main_page=product_info&cPath=1_24&products_id=1211&language=en
Feb 26, 2015 | Office Equipment & Supplies
I have a problem with my power supply ,my main fuse is broken when they have put in 220v source in place of 110 volt all so I have found that the power transistor (c3552) is also broken I like to have a...
If this is a 220v rated fuse then it doesn't matter that's ok, your transistor is broken or burn't then this could be a problem. The only place I know of is servicemanual.net, that's manual or with an s
Mar 02, 2011 | Televison & Video
Gas furnace gmt090-3a, has a one link code. the electric gas gas does not get 24V usually. problem is intermittant, wiring appears good, no kinks, or fraying. bypassing the thermo sensors for the 24v...
Sound like you have figured it out. Good job. I suggest that you verify the results next time that it fails. When it fails. measure voltage at the "w" terminal on the circuit board. If 24 volts is present here and not at the gas valve terminals then you are absolutely correct. It is the circuit board.
Dec 18, 2010 | Goodman GMS90703BXA Heater
Wiring diagram for Thermoking V700MAX
Red or R is the "Hot leg" of the Transformers 24volt supply,
Common or C is the "Neutral leg" of the Transformers 24 volt supply;
and the side of power to which ALL the 24 volt control circuits
terminate to complete the circuit, example; Heat=W, Cool=Y, Fan=G.
Upon a call for heat a switch closes betwen the Red and White Thermostat terminals.
The stat sends the 24 volts to White or W for the heat circuit on W on the
furnaces LVTB low voltage terminal board.
Yellow or Y goes from Thermostat to furnace Y on LVTB, which is simply
a connecting point on its way to the AC units 24v contactor coil located outdoors.
It actually isnt even attached to the furnace many times as it serves no purpose there and simply
continues to the AC unit with the copper lineset that the AC unit feeds.
The remaing 24 volt Thermostat wire goes back to common on transformer to complete the Yellow
24 volt control circuit.
Green or G exits the Thermostat and connects to G on LVTB for the fan relays 24volt coil
and returns to Common to complete the Green 24 volt control circuit.
O is for a Heat pump reversing valves 24 volt solenoid, and return to Common as all 24v circuits must to terminate or complete the circuit.
Some parasitic type Termostats need the 24v power to run, some are battery, some are both.
Nov 01, 2010 | Heating & Cooling
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
ATX-300GU PSU: 32V around Q4/Q5 circuit
could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
May 17, 2009 | AOpen Power Supply: ATX-300GU (PS4300GU)...
old marine
old marine
