Question about Dometic Refrigerators
We have a 3-way Dometic fridge in our camper and the 3-way converter is not working. It keeps going to "check" and turns off.
    Top Expert:
  • Dometic Master
  • 8,143 Answers
Board needs 12 volts + to run fridge
Posted on Nov 05, 2017
  • 51 Answers
SOURCE: my dometic rm4213s model fridge
If the freezer is getting cold check for air flow in the back it needs to be free of any obstructions. Next adjust the sensor on fins inside the fridge it works as your temp control move it up and down for control.
Posted on Sep 08, 2008
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
motor1258
  • 6674 Answers
SOURCE: HOW TO START / OPERATE THE FRIDGE
Here's a link to download PDF file for your fridge.
http://bryantrv.com/docs2/docs/rm2193.pdf
Posted on May 09, 2010
motor1258
  • 6674 Answers
SOURCE: Have dometic three way fridge in pop up truck
Find thermistor/thermostat that is usually attached by plastic holder at back on one of the fins in fridge compartment. Pull it off, and move it over to left 2 fins, then give 24-48 hrs and see if any change.
Posted on Jun 17, 2010
sodeep
  • 3267 Answers
SOURCE: Dometic RM2652. The fridge will not work when it is plugged into AC.
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Posted on Apr 30, 2012
2008 camper. fridge keeps switching over to gas. Turned it off & back on, it goes back to AC. The camper is plugged into a 50amp outlet & all else works fine.
Check your fuses and circuit breakers to see if any are tripped or blown. If you are handy with a test meter you can check for power at the refrigerator control panel. There will be a vented cover outside behind your fridge and there are two leads going to a heating element. You can check for power or continuity through the element.
May 12, 2015 | Dometic RM2852 Refrigerator
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Replaced control board have 115 to board can't get 12v nothing lights on frig or in side where does 12v come from voltage is good in camper Couchman with Dometic md RM2652
The 12V comes from 2 wires that come from RV and affixed to a terminal block on fridge. Insure you have 12V at those wires. Also check the fuses located inside the main electronic board. ArctiCold Refrigeration We keep it cold 28659511-ac6f-4f0b-b8c3-c7ac7cf165ac.jpg 8e5a2b6c-5f1f-429e-8512-595071232c90.jpg
Aug 29, 2013 | Dometic Refrigerators
Our 1995 30FL Leisure Star camper Dometic fridge is not working. the camper is level. the Check light goes on after a few moments of turning it on.
Give Arcticold Refrigeration a call toll free tech support 1-888-782-6665 We will require the model number so please have that available. We will require more info to help with this problem such as results on electric, ect. ArctiCold Refrigeration We keep it cold da1720cc-2c8a-48ab-b560-ebb5655e2d6c.jpg
Aug 24, 2013 | Dometic RGE400 Top Freezer Refrigerator
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Apr 30, 2012 | Dometic RM2652 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
The fridge will not turn on. Should I be turning on the 100 switch, even if the camper is plugged in, and the lights are working?
Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
Sep 01, 2009 | Dometic WA3210 Compact Refrigerator
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Refrigerators Logo
41 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
