Question about Garden
Homelite zr s825cdv
How is the fuel line routed
2 Suggested Answers
SOURCE: What fuel mix for homelite
40:1 for chain saws.
Mixing instructions shown on back of 2-cycle oil container.
Posted on Jan 02, 2011
How do the fuel lines rout on a homelite 45 including from tank, primer bubble to the carbeurator
Without the UT number from the saw won't be able to give more detail carburetor hookup. Here is a generalize fuel hook-up diagram.
Depending on the carburetor both of the fuel lines can be on one side only. The suction line connection for the primer is usually closest the the metering diaphragm.25331542-pzxv2dmyt02yqunciumgycfv-5-0.png
Dec 21, 2014 | Homelite Garden
Fuel line routing
i took the homelite 330apart in doing so the lines broke no problem i needed to replace them any way so now im confused to where they all go
Oct 01, 2013 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
Diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Oct 22, 2012 | Homelite Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 | Garden
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
I need to know the procedure for replacing the fuel line from tank to carb on my old blue homelite Xl12
The procedure is logic and common sense buoyed up with as much information as you can obtain.
This is a typical fuel system and a tip or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. (About 30 XL-12s; I defer to you)
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good Luck. HTH
Lou
Feb 17, 2010 | Homelite Garden
Homelite zr series z25mhv/160mph fuel line and gas tank parts the fuel line dicinigrated where the fuel filter hooks to
Take a piece of your old hose to your local hardware store and compare the ID of PVC tubing, this should work fine
Mar 24, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
