Question about Triumph TR7, Triumph TR8 Carpet Dashboard Cover 1094-0CGY - Dashboard Covers
Seized engine dolomite sprint
Just brought a dolomite sprint and the engine is seized because its been standing for three years who can I un seize it without taking engine out
    Top Expert:
  • Dash Designs Master
  • 42,084 Answers
You are asking the impossible because if you try and turn the engine in this condition it is very probable that you will break rings and or the piston lands between the rings. You will be using the rings as rust scrapers and that will damage the bore. However having pointed out the problems facing you I can only suggest that you pull the plugs and fill each bore up with a penetrant such as wd 40 or crc and let it sit for say a week and see if there is any movement possible in the crank (by hand). I would say that you are in for a costly rebuild or a motor from the wreckers or an exchange unit.
Posted on Jul 26, 2013
2001 ford windstar engine may have locked up what do i do with out junking the vehicle
If you want to keep it, best bet is to find another engine, exact same engine, and same year preferable, and put that in your windstar.
But you said "may have locked.." Anybody handy with wrenches could tell you if the engine is seized up or not. Once seized, they don't come unseized, so just a matter of seeing if the crankshaft still turns inside the engine. If not seized, it may be worth seeing if engine is still useful. But if it locked up, the rebuild cost is too great to make it worthwhile. Just find another engine.
Nov 03, 2016 | Ford Cars & Trucks
I have a 2004 explorer 4.0 soch motor and it seized how can i break it free
Assuming you could get the motor to unlock, it would require a complete overhaul in order to run properly again because either the crankshaft bearings or the camshaft bearings (or both) and possible the pistons themselves have welded themselves to the engine internals. Most likely a new crank, cam, pistons as well as having the block bored and resurfaced.....get the drift?
Dec 10, 2015 | 2004 Ford Explorer
Rear brakes on passanger sided is locked up or does not un lock on my 1999 chevy silverado 4x4 1500 what could be the probleom
I GUESS 4 WHEEL DISK BRAKES
I WOULD CHECK CALIPERS SEIZED UP
PARKING BRAKE SHOES BUNG UP
KINK LINE TO CALIPERS
SEIZED PARKING BRAKE CABLE
CALIPER SLIDER PINS SEIZED UP
FAULTY ABS RELAY VALVE NOT RELEASSING
A FEW THING TO CHECK
Apr 15, 2011 | Chevrolet Silverado 1500 Cars & Trucks
While driving my 2005 armada began leaking fluid & smoke poured from the engine compartment..then the engine just seized completely. I had it towed to a local aamco. Have these models had transmission...
if the engine seized and smoke was pouring from under the hood, its most likely not the tranny. are you sure the engine seized? what color smoke poured out? can you still shift the tranny? if the tranny broke, you wouldnt be able to start your car, however, that doesnt mean your engine seized, that's just a fail safe designed to keep you from destroying your engine internals when the tranny seizes. if you can still shift, the tranny isnt seized and you should put the vehicle in nuetral and try to push it, if it moves, the problem is the engine. cant tell you much more than that without specifics. also: if you are driving a vehicle with recalled brakes, you arent very smart. if your brakes have been recalled, you need to be using aftermarket brake parts. dont have the dealer service your brakes, go to a brake shop or a parts store and get brake parts that meet original equipment standards, but are NOT original equipement. if you have already switched from factory brakes to after market brakes, then whomever has been installing your brakes doesnt know what they are doing. i deliver pizza part time and put tremendous wear and tear on my brakes, yet i still get 3 years out of cheapo brake pads. 4 sets of brakes in 5 years is rediculous, and i would find a new mechanic if i were you.
May 17, 2010 | 2005 Nissan Armada
Ran cb 750 with low oil no seized . how to un seize
Only safe way is to disassemble motor. As you dont know if the bearings have welded themselves together.
Any " quick fix" will ultimately end in tears and expense.
The bikes age justify s the expense and you might as well throw a Yoshimura kit in it and get some more horses while it's in bits anyway.
Mar 28, 2010 | 2005 Honda CB 750
My VW Golf over heated, the engine cutoff in the middle of the road and now won't start. what could be wrong?
If you over heated significantly the cylinders will expand and the engine will seize.
If seized it is dead.
It can get to a point where one cylinder seized and it will cause major problems with the crank and cams. Both of which are not something you can fix at home or have a quick fix solution.
There is a way to check if you are seized. Try turning the engine over using a wrench of ratchet on the crank bolt. The crank bolt will be on the lowest pulley on the back of the engine where the belts run. It is usually about a 19mm bolt.
Warning: turn only clockwise and never counterclockwise.
If you can turn the engine over it is not seized. If not you have a seized engine (sorry about that).
Start there.
Hope this helps.
Feb 28, 2010 | 1999 Volkswagen Golf
Clutch seems to be seized because bike has been sitting for years
Is the clutch lever sized or is the plates sized?
Usually the plates inside sizes, all you have to do is select gear 2 or 3 without starting the bike's engine,operate the clutch lever and push the bike,it should release, the rear wheel should now rotate freely with clutch lever in operation and in gear.
Hope this helps!
Nov 28, 2009 | Yamaha YZ 250 Motorcycles
Standing out for a year now no start
If you didn't start it for a year or turn the engine over you may have a seized engine. Not a fun thing as there is no easy way to un-seize it.
You can try removing the spark plugs and spraying a small amount of penetrating oil in each cylinder but the truth is, if the cylinders sat long enough to rust and freeze up like that, you would most likely do more damage to the engine. Best option. Put a socket on the harmonic balancer nut and use a breaker bar to try and turn the motor, if it turns you have another issue if it doesn't turn you will need to rebuild the motor.
Sep 10, 2009 | 2004 Chevrolet Aveo
I have a brrigg and stratton 8 hp i got the moter un seized and got the flywheel sping and nothing happed and when i turn the key the flywheel will spin for a sec and then stop and i put a new spark pug in...
What made the engine seize in the first place. If it seized from just old age and setting the valves are most likely stuck open. Most of the time the valves are what makes an engine seize from setting. You just moved them enough to let the piston move up and down they are more than likely rusted. Check for compression.
Aug 27, 2009 | Briggs & Stratton Garden
Volkswagon polo brake load sensing valve is seized how do i locate & fix the problem
volkswagen polo rear brake load sensing valve linkage has seized!!!
What can i do?
Apr 17, 2009 | 1996 Volkswagen Jetta
Triumph TR7, Triumph TR8 Carpet Dashboard Cover 1094-0CGY - Dashboard Covers Logo
55 people viewed this question
Top Dash Designs Vehicle Parts & Accessories Experts
ivan whisker
ivan whisker
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Dash Designs Vehicle Part and Accessory Expert? Answer questions, earn points and help others
