Question about Yamaha GX-505 CD Shelf System
Volume control on unit failed, r/c volume okay.
Over a period of a few weeks, the volume control on the unit became intermittent, then failed totally to respond to rotational movement. The remote control works fine. Have removed volume control knob assembly from PCB (left body attached to PCB). No obvious sign of excessive wear on contacts (knob or PCB-attached contacts). Small amount of factory-installed grease relocated (to simulate new product). Re-assembled whole unit, problem remains (naturally...) Is problem most likely (or has experience proven): - volume control assembly worn out, needing replacement? - contacts (within control) needing 'repositioning', to ensure greater friction between surfaces? - analogue components (pull-up and/or pull-down) between volume control and digital IC failed? - digital IC failed (no longer 'reading' changes from volume control)? (All of the above?!) Thanks...
  • Anonymous Dec 02, 2007
    Same problem on RX-V620RDS. Not volume control - gives out correct pulses. Need schematic to trace signals. Can't find on net - anyone got one?
SOURCE:
  • 238 Answers
SOURCE: sound
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Posted on Dec 30, 2007
  • 31 Answers
SOURCE: Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Posted on Sep 16, 2008
SOURCE: Remote no longer works for volume control
Guys, I might have accidentally found the problem because the fix worked for me :). I have the RX-V995 and for the last 2+years or so, I had resorted to getting up and using the knob manually for volume control. System will show 'voluem up/down' in the display, but the knob didn't rotate. Same problem as yours.
I was getting ready to buy the service manual, find the knob motor which I thought was the main culprict and replace with a new one.
So I took out the top cover (just a few screws), the front face-plate (again just a few screws. The inner details were all visible. The volume knob circuit board was vertically placed. They were all covered in a good layer of dust. I got my Dyson vacuum cleaner and gently and carefully tried to **** up all the dust that had settled down. With soft front brushes, I agitated the dust I couldn't reach with dyson wand direclty, once dust were loose, dyson did a great job even with picking up those last dust pieces.
I couldn't succeed in taking apart the volume knob circuit board, as I was still awaiting for the service manual. I put all the covers back on and guess what? I used my remote and the knob was moving again. Responding very well, the knob made the full turn, when I was on the remote. It has been working perfectly for the last few days now.
I think I know what was happening. Teh top of the RX-V (and I am sure many Yamaha receivers) are very porous to allow for good heat dissipation. Over time, this allows a large amount of dust to collect on top of the parts. Most parts are electronic (not mechanical) and hence don't get affected by the dust. But the few mechanical parts might have adverse affect if dust settles down in between the rotating mechanisms.
My volume knob had stopped responding to remote command, very slowly. Initially it worked a little, missed a little, then it missed a lot and eventually it didn't rotate. That proves the theory to some extent that if the motor had completely failed, it would stop working from the get-go, not intermittently. Dust build-up provided intermittent contact between the parts and hence the response was intermittent.
The dyson vacuum did a great job in pulling out those fine dust from such parts and amazingly, things are looking very good at present. Honestly, I hadn't the slightest hope that vacuuming would fix the problem. I had vacuumed to make it easy for me to work on the parts :).
So, it doesn't hurt at all to just give it a try. Do open the covers so that you can reach closer to the real boards and parts.
Good luck and let us know!!!
cheers
PN from San Jose, CA
Posted on Jan 28, 2009
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
AJIN G
  • 6694 Answers
SOURCE: I own a yamaha surround
hi,
The volume control in AVR receiver is a like press button switches. There will be two miro switches inside the volume control. When you rotate the volume control in the both direction the micro swtich get activeted and that will result in increase or decrease in volume. In you case the contact of the micro switch inside the volume control is faulty. It a common on problem to AVR, because we vocationally rotates the volume control, this will make the contact of the micro swich dirty. If you can do one thing Go to some electronic spare part shope near to you and buy a swich cleaning oil. Open the AVR's top cover and put two or three drops of the swtich cleaning oil to the top of volume control. rotate the control in both direction for some time. Then power ON the AVR and check is it jumps. If then also it make the same problem then you have to replace the volume control wit a new one . You can see the volume control behind the volume knobe.
OK
Posted on Sep 05, 2011
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Air/Heat Volume control knob does not work in 04 Santa Fe
Try replacing you blower resistor. Usually they short out one speed at a time
Dec 04, 2017 | 2004 Hyundai Santa Fe
Hi my surround sound system keeps resetting its volume to 30- quite annoying when your trying to watch something! It was working fine for three weeks then this. There are no crossing wires, all wires...
If rotary volume control, I would work the control (with unit off) back and forth at least a hundred times to thoroughly clean the wiper. If a push button unit I would chemically clean its contacts.
If unit still does it then the volume control chip has a poltergeist in it. If there is an audio output on unit see if the anomaly also appears there to help localize its location in circuit.
Sep 12, 2017 | Audio Players & Recorders
My Rotel RA-931 integrated has an intermittent left channel. It occasionally cuts out or loses most of its volume. The key thing is this: if I crank the volume it'll suddenly come back and be okay for a...
This could be a bad solder joint, or dirt in the volume control. Try spraying the volume control with Servisol Video 40, available from electronic shops such as Maplin, or Radio Shack.
Dec 22, 2009 | NAD C272 Amplifier
Harmon kardon hk695-01,13 - Intermittent "gargling" noise
the noise is sometimes caused by dust in the volume control.
i would suggest blowing the dust out around the volume control if there is a manual control on the unit. use a small can of compressed air.. buy it at local walmart or computer store.
Apr 28, 2009 | Harman Kardon HK695 Computer Speakers
My cd player works intermittently
i dunno wot is happenin but the same thing is happenin 2 my cd player nd it reli annoyin! please sum1 help!!!
Aug 28, 2008 | JVC KD-SX980 CD Player
Reciever RX V800
I bought my RXV800 in late 2001. This amplifier is absolutely fabulous and I understand others -like me- being unhappy when it starts to fail. I have the volume control issue as well, it started to work normal for at least 5 years, then there was a period of 1 year that the volume neither went up or down when you turn the volume control and then finally a 3rd phase was that it more or less works reverse.
It is solvable and I repaired it myself for $ 0,0. The only requirement is that you are a bit handy. You need to open the box and find yourself a way to the volume control (and you know where this sits of course) because this is the one that needs to be repaired. This is 35 screws away from you in total but this sounds a lot worse than it is !
It is indeed the volume control that needs to be repaired. In an analog amplifier this component would contain a resistor (potentiometer) but hey this is a digital volume control and looks from the outside the same but isn't at all. You need to take this volume control with 5 contacts of its print with a soldering iron. Open this potentiometer lookalike and clean it with some absorbing paper. The issue is that there is a kind of oil/grease from the shaft (which is there in order to turn smoothly) which has leaked into the area of the contacts in the middle. Just clean it and turn 50 times with it in order to spread the remaining oil/grease if there would be any. Close it again, solder it onto its print and switch on the unit... you will see that it is repaired... not for 1% or 10% but for the full 100%.
Hope this helps !
Regards,
Dirk
ps : enjoy your RXV800 !
Jul 03, 2008 | Yamaha RX-V800 Receiver
Model yamaha RX V800 the volume button when turned clock-wise....lowers volume....and visa versa....what the heck is the problem.....frustrated,,,Mik'ie :-(
Hope this helps !
Regards,
Dirk
Jul 03, 2008 | Yamaha Audio Players & Recorders
Dual head unit help!
You can try contacting the manufacturer to see if it can be repaired.
When you have this type of problem, it's generally due to the rotary encoder failing. It's unlikely anyone else will have parts.
Dec 22, 2007 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Yamaha GX-505 CD Shelf System Logo
129 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
