Ho to load staples in a rapid 90ec stapler - Office Equipment & Supplies
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: Can not figure out hold to load our 90 electric
if there is a pull strip on the back slide it out and place them in and then slide the trap back in.... or underneath you may be able to remove the compartment that holds the staples place them in that and put the piece back on.... or it may be standard and the top may remove
Posted on Dec 01, 2010
jesusandsean
SOURCE: TRYING TO LOAD A STANLEY
Have you looked at the spring for possible loss of pressure.
Posted on Mar 05, 2011
When on the stapling process even when it's pushed down the staple wire is not cut.
Probably too late but, here is what you need to repair this expensive stappler instead of buying a new one:
https://www.stapleheadquarters.com/ItemForm.aspx?Item=DUAX29
May 16, 2016 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
Rapid 90ec stapler
If you are a teacher, get a pair of scissors to get the staples out
Dec 01, 2013 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
730 people viewed this question
k24674
jasbo
jasbo
