Question about 1999 ISUZU TROOPER 229501 Flywheel - Replacement Plate
ISUZU 3.0 TDI KB 2007 MODEL ENGINE PROBLEMS
Hi i have a 3.0 tdi isuzu you drive the vehicle for plus minus 5 days then the engine looses power and the vehicle starts to smoke.After fitting a replacement battery or charging it the vehicle runs smooth again for 5 days.I replaced the altenator and tested the charging of it.The fault codes i get is P0704-6 clutch switch input circuit high,P0216-A injector timming control circuit,P0110-1 intake air temp.circuit .Please help.The fault codes is not making sense ,related to the battery
  • 22,156 Answers
No it makes sense to me ,this isuzu is a GM related product and if its about 10 yrs old then this would make sense with all manner of funny codes .The problem i think is the computer and its no doubt bolted to the cylinder head or close by resulting in it running hot which with age causes problems.This problem i get with the opel astra range including the zaffiro .By changing the battery or disconnecting it you are effectivly resetting the computer clearing the codes .dont get this problem with the daewoo which has the same engine but the computer is nowhere near the engine on these cars
Posted on Jul 26, 2013
Isuzu KB 300 TDI not starting fault codes 12 .,51
welcome to the USA forum
the country with zero KB trucks and zero books on it.
why ask here, (might take a year to get help , knowing that)
no country stated
are you in AFRICA>? seem true no? made there too.
an your kit factory (GM/ISUZU)
flash codes.
if you buy the book at your dealer that is all covered.
for sure...
Jan 01, 2017 | Isuzu Cars & Trucks
Good Day. How do I set the valves gap for a Isuzu 161Z motor, is it on rocking stage or completely loose??
completely loose -- piston on tdc compression stroke
if you know the firing order of the engine if no 1 piston is on compression stroke , the next piston to fire will be on valve overlap or valve rock
when it is in the valve rocking situation then no 1 piston will be at maximum clearance for adjustment purposes
repeat the process for the next piston to fire
for example "- 6 cylinder
firing order -- 1-5-3-6-2-4
with no 1 on compression , no 5 valves will be rocking, no 5 on compression no 3 valves will be rocking with no 3 on compression no 6 valves will be rocking and so on
Nov 26, 2016 | Isuzu Cars & Trucks
How does one set pump timing on Isuzu kb 300 tdi
the 1000th post for this in a USA Forum
we dont have KB trucks here in USA. or books on it. zero.
where is yours.
africa.
or Australia.
on YEAR car stated,
3.0L diesel pump timing. google with the real engine name
and will win.
3.0L is not it.
Oct 19, 2016 | Isuzu Cars & Trucks
My isuzu kb300 2005model gives white smoke and sometimes it cant accelerate and engin light comes on
KB
Welcome to the USA Fixya.com forum!
we don't have KB here. sorry.
History.(1 line, all bad)
2005 - Isuzu dealers in the United States have only one model, the Ascender SUV,
and guess what?, it's a rebadged GM car here, no more cars here, real isuzu.
KB are in Africa, Australia and in EUROPE not here in USA. so no books here to cover it.
nor is it covered here, at our great ,Mitchells online.
The KB300 is a 2.999 liter diesel, some are TDI. (most?)
and is called the 4JJ1-TC. (t= turbo)
That is direct injected, (means check turbo , and scan it first) after checking fuses.
The Check engine light on, same deal.
Check filters. for fuel and air.
2004 the D-max , family , introduced the DDI-ITeq common rail diesel engine.
So next time post your country.
And all symptoms.
power loss?
smoke?
Noises?
warning lamps.
etc.
Feb 27, 2016 | Isuzu Cars & Trucks
Isuzu kb300le does not want to raise the rev's(RPM)
KB (no year)
2005 - Isuzu dealers in the United States have , the Ascender SUV,
and guess what?, it's a rebadged GM car here, no more cars here, or Isuzu I-series same.
And all symptoms.
power loss?
smoke?
Noises?
warning lamps.
does turbo seem dead, only you can hear it?
etc.
our closest car matching yours.
is Chevy Colorado 2004_+
and Isuzu I-series.
both with GM drive lines. all petrol !
300 tdi lx. Where can I get a diagram of engine room fuse box?
go to isuzu dealer and ask yet>?
the will have the operators guide you lost...
no year no joy
in what country
this is a usa forum and we dont have that car .
what car, you never said what it is.
a KB
or a Bakkie.
or? just what?>
Feb 23, 2016 | Isuzu Cars & Trucks
My isuzu kb 300 lx tdi cuts off engine while idling. It also revs itself at 1200 revs/min when engine check light comes ON.
no year?\
no country.
no joy.
no engine, or is 300 means 3liter?
we dont have KBs in USA> this is a usa forum. so...
so the operators guide says.
CEL on get service.
or if handly DIY guy, SCAN IT yet? that is what the lamp means.
SCAN me now. on all cars 1988 to now, in usa,
and 2001 and newer on other countries. varies by country....
as does EFI systems used,.... big time.
Apr 24, 2015 | Isuzu Cars & Trucks
My isuzu kb 300 lx tdi year 2006 engine cuts off as if no fuel is supplied. Once engine check light comes ON it revs itself at 1200 revs/min
why double post
all added year.
but what country
and what engine exactly using real isuzu name for your engine.
Horse power trooper 3.1 tdi 1998 engine
not much,takes 16 second to get to 100km/hr,but then again I don't think you bought it for speed.
Jun 20, 2009 | 1999 Isuzu Trooper
1999 ISUZU TROOPER 229501 Flywheel - Replacement Plate Logo
261 people viewed this question
Top Fidanza Vehicle Parts & Accessories Experts
Jim Y
Jim Y
Colin Stickland
Colin Stickland
Ray Jefferson
Ray Jefferson
Are you a Fidanza Vehicle Part and Accessory Expert? Answer questions, earn points and help others
