Question about Zoom 5551A Modem
Zoom X5 ADSL light not blinking
I have had this Zoom X5 Modem for 3 years. Normally, when I powered up it, the ADSL light would blinking for a while (about 10 to 15 seconds). After that, it would lighting static. But one day, one nice day, when I powered it up, the ADSL light was not blinking anymore, it just keep light on. And the modem could not connect to the line. I can still connect to modem using my PC, change setting, configure it, change user name and password, but cannot access to the line What is the problem with it? Please help me. Thanks in advance.
  • duongpv Sep 10, 2007
    Yes, now I have already bought a new one, and of course, it works fine. I just tried to figure out what was happenned to the old one. Who knows, may be it would happen again with the new one.
    Thanks for replying
  • kaka_deptrai Jun 18, 2008
    i want password defaul of modem zoom x5 ADSL
    Sergeant:
  • 457 Answers
May be your ADSL modem has clapped out it sounds like it. You say you can connect via the PC modem that means the dialup is working......I imagine you have tried the ID logon and password for the ADSL also and it still wont connect. Try support at your ISP and if it still dont connect then it must be had it, you will need to buy another.
Posted on Sep 09, 2007
  • Peter Hirawani
    Peter Hirawani Sep 10, 2007
    No I dont think it will happen with the new you will have a few more years with that one......of course if you want to repair the old one then may I suggest you contact the manufactures but it may cost more to repair it?
SOURCE:
My zoom adsl x5 modem/router will not let me go wireless
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Mar 09, 2010 | Zoom ADSL X5 Router (5554-72-00)
Zoom X5 ADSL modem doesn't autodetect
All modem has a reset button on the back of them. Hold in on it for about minute. Then when the modem reboots input all of your information back in.
Dec 16, 2009 | Zoom X5 5654 DSL Modem (DH5654)
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
Zoom ADSL X5 dropping connection
It is a sure case of UR AC ADOPTER MALLFUNCTIONING. plz change your AC Adopter your problem will be solved.
Aug 14, 2009 | Zoom ADSL 5554 X5 Router (5554-00-00)
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
USB and ADSL light blink, no logon
I trashed the Zoom modem and get an Actiontec. This is the second Zoom modem that I have had that bit the dust.
Jul 15, 2008 | Zoom ADSL 5554 X5 Router (5554-00-00)
Zoom ADSL X6 Modem "Link" Light Suddenly Blinks Continuously
the modem may have gone faulty so if your isp provided it ask them to replace it if the modem is in warranty period and if your isp provides internet connection through the phone line then first please try plugging the modem on main socket in with an adsl filter plugged in and if this is not the case then problem is definately the line through which the broadband signal come to your place which is suppose to be sorted out by your isp.
Mar 12, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom 5551A Modem Logo
776 people viewed this question
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
