Question about Kitchen Appliances - Others
Cannon electric blanket
Suddenly stopped working. The problem seems to be inside the box that regulates temperature. I have had it only six months. What's wrong? can I fix it or get it fixed?
HVACRH20
  • 237 Answers
SOURCE: I am getting [P1] code on my temperature indicator
Could you please re-post with the model number so I can look up the codes?
Posted on Feb 02, 2007
  • 25 Answers
SOURCE: Moffat Electric oven
check your breaker
Posted on Dec 12, 2007
SOURCE: Electric ring stopped working on my T1250 Cooker Hob.
MY PHONES RINGER STOPPED RONGING MEYBE THERES SOMETHING WRONG WITH IT
Posted on Jan 18, 2008
  • 1073 Answers
SOURCE: Frigidaire is freezing everything
yea the proper fix for the machine is a control assy part number is 5303918283 this is the complete kit.
sounds like that they just replaced one of the parts in the kit
this is the factory proper fix
Posted on Apr 15, 2008
SOURCE: electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Posted on Dec 31, 2008
Can this blanket be washed?
Yes, but follow these instructions. In particular, do not immerse the temperature control switch , which has to be removed from the blanket. If it is permanently attached, then hand washing only is possible.
http://www.sunbeam.com/garment-care/care-and-cleaning/care-and-cleaning.html
http://www.howtocleanstuff.net/how-to-wash-an-electric-blanket/
Dec 03, 2015 | Sunbeam Electric Blanket - queen
Dreamland electric double blanket suddenly stopped working after making bed in the morning.
Yep..the element, or wire inside the blanket is probley broken, or touching just enough to work sometimes. No easy fix for this..and it would be dangorous to do it anyway..
Dec 29, 2014 | Home
Winter's tale electric heating blanket flashing "F"
I\'m having the same problem as Jenn. Tried unplugging it and left it for a day. Both sides are now not working. How can I get it to work again? Husband is having a hissy. Please just tell me what to do. or tell me how to download the manual. Haven\'t had this for very long 2 months. if any help.Mary Ellen I did love this when it did work.
Nov 19, 2013 | Winter's Tale Microplush Electric Blanket...
Can you use an electric blanket with a memory foam mattress?
Yes you can. Though memory foam mattresses are temperature sensitive and absorb temperature from the climate, but still it is perfectly fine to use an electric blanket with a memory foam mattress. For more on how to use an electric blanket with a memory foam mattress, you can read this article
http://www.ehow.com/how_5768635_use-electric-blanket-memory-foam.html
Jack
Jan 12, 2013 | Sleep Innovations 10-Inch Memory Foam...
I bought a Sunbeam electric blanket in december and only used it for about 3 months until it stopped working. i have done nothing that would cause this to occur and after searching online found that this...
The only thing you can do, other than pull all the wire out to test it, is check the temperature control. If you have another you know works or can borrow one to test the blanket, that's the easiest. Else, you will need to use a "Glow Stick". A Glow Stick is an electrical tester that does not require physical contact with a bear conductor to detect voltage. They are available at Hard Ware stores, Menard's, Home Depot, etc. Plug the blanket controller into the wall outlet and touch the 2 wires near the thermostat. If it glows, the cord is good and the outlet has power. Now test the wires coming out of the thermostat that go to the blanket. Turn the thermostat way up and down and see if the light glows. If no, the thermostat is bad. If it glows, indicating power has made it through the thermostat, continue to test along those wires to the blanket. If you have power at the plug on the blanket, continue onto the blanket along the wires that provide the heat. The light will continue to glow on-till you get to the break in the line. When the light goes out, that's the break point. If you do find a break in the blanket and would like me to walk through the repair, I will be happy to. The Glow Stick is a good investment for safely testing anything electrical without the risk of being shocked. Please rate this for me. I am new to the site and need to improve on writing what I am thinking. Let me know how it goes for you, OK?
Roger
Apr 02, 2011 | Heating & Cooling
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
Eletric blanket timer
If walgreen can't order the part I would try places like appliance stores,like D&LAppl.
Mar 13, 2009 | Heating & Cooling
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Kitchen Appliances - Others Logo
478 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
