Gprs on ''gprs compaitable handsets'' works only through specific gprs settings, the settings are different on every network. To activate gprs on your phone you should first get the gprs settings, then install and activate the settings as default. You should contact your service provider, they will send you the gprs settings, then do as i mentioned above.
Rate my answer...
Hi, to access Internet on your Cherry Cellphone you need to activate GPRS and download GPRS settings for your cellphone. Please contact the Customer Care of your Cellphone Network Carrier to download the GPRS settings or to enter the GPRS settings manually on your Cellphone. After the GPRS settings completion and activation, you can access Internet on your Cellphone.
yes, nokia 3200 has a gprs
go to web to access the internet with gprs connection
before you can make gprs connection you need to setup the gprs setting
the gprs setting is dipending on your simcard provider, if you did not know the gprs setting contact your sim customer care to ask about the gprs setting
i hope this helpful
thank you for using fixya
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network: Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′ Note : The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated
for activating gprs you should contact your service provider.they will send you gprs settings and just by opening it you can activate gprs in your mobnile.
