Question about Wahl 5598 Beard Trimmer
Blade assembly re-assemble blades
2 Suggested Answers
  • 10865 Answers
SOURCE: CLIPPER BLADE POP OFF...WILL NOT GO BACK ON THE
hi. it will go back on. Soak it in real hot water for a minute and then put it on. Joe
Posted on Mar 20, 2010
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
Assembly issue
You mean the knob is connected directly to the blades? I'm not sure what you mean by blade knob, but does turning it turn the blades? If so, I'd suggest wedging something between the front grill and the blade to prevent it spinning and try to twist the knob off. I tried to find a owner's manual for your fan, with the assumption that there would be assembly instructions, but was unable to find one. Do you still have the owner's manual? And if so, are there any assembly instructions in there? How did the back grill come off, if you can't get it over the knob? Or are you assembling it for the first time. If you are assembling it for the first time, was the knob there when you got it? That seems poor design if so.
Sep 03, 2007 | Honeywell HS1750 Stand (Pedestal) Fan
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
I own a 2003 Dodge Durango. The coolant fan stopped working. I found a plug loose near the fan. Is it possible it came unplugged? If yes, then is the plug inside the fan case? I have looked all over and...
I couldn't find the plug or wire on the diagram on my online resource, either. The fan must have a cable going to it to operate, somehow, though, I agree.
Engine Cooling Fan Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Fan blade/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front - threads on viscous fan drive are right hand. CAUTION
      Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
      Do not unbolt fan blade assembly from viscous fan drive at this time.
    • Upper fan shroud attaching hardware
    • Upper fan shroud and fan blade/viscous fan drive from vehicle CAUTION
      Do not place viscous fan drive in horizontal position after removal because silicone fluid in the viscous fan drive could drain into its bearing assembly and contaminate lubricant.
    • Four bolts securing fan blade assembly to viscous fan drive.
To Install:
  1. Install or connect the following:
    • Fan blade assembly to viscous fan drive.
      1. Torque to: 17 ft. lbs. (23 Nm)
    • Fan blade/viscous fan drive assembly and upper shroud into vehicle
    • Fan shroud retaining screws
    • Fan blade/viscous fan drive assembly to water pump shaft
    • Negative battery cable
Sep 30, 2010 | 2003 Dodge Durango
How to remove fan on a 5.2L engine
Hi, 5.2L Engines
  1. Disconnect the negative battery cable.
  2. The viscous fan drive and blade assembly is threaded into the water pump hub shaft. Remove the fan drive and blade assembly from the water pump by turning the mounting nut counterclockwise as viewed from the front while securing the water pump pulley. Do not remove or unbolt the fan drive and blade at this time.
Fig. : Fan blade and viscous drive (click for zoom)
The threads on the viscous fan drive are right hand threaded.
  1. Remove the 2 fan shroud-to-upper crossmember nuts.
  2. Remove the fan drive, blade and shroud as an assembly.
WARNING Do not place the viscous fan drive in a horizontal position. If stored horizontally, silicone fluid in the viscous fan drive could drain into its bearing assembly and the assembly would have to be replaced.
CAUTION Do not remove the water pump pulley-to-water pump bolts. The pulley is under spring tension.
  1. Remove the 4 bolts securing the fan blade assembly to the viscous fan drive.
To install:
  1. Install the fan blade on the viscous drive. Install the bolts and tighten them to 17 ft. lbs. (23 Nm).
  2. Position the fan shroud, viscous fan and blade into the engine compartment as an assembly.
  3. Position the fan shroud to the radiator. Insert the lower slots of the shroud into the crossmember. Install the upper attaching nuts.
Ensure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
  1. Install the fan drive and blade assembly to the water pump shaft and tighten the nut.
Ensure there is at least 1 inch (25mm) between the tips of the fan blades and shroud.
  1. Connect the negative battery cable.
Take care
Aug 04, 2010 | 1993 Jeep Grand Cherokee
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Jenn air jbl800 blade assembly?
Got the blade assembly make me an offer! Contact me at freedom4u@myarbonne.com .
Andrea
Mar 15, 2009 | Jenn-Air JBL800 Work Top Blender
Andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Apr 20, 2008 | Health & Beauty
I have broken my HP Photosmart R817
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Mar 23, 2008 | HP Photosmart R817 Digital Camera
Wahl 5598 Beard Trimmer Logo
47 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
