Wcarg010ee aircon stops, showing Fr
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Carrier Aircon WCARG010EE 1 HP
You must check if there is power to the fan to confirm if there is failure of the fan motor. Since the FR display indicates there is possibility that the power is initiating.
If the remote unit is not powered from the main unit then it is possible that the main control section must be checked for failure in the control unit.
Check for faulty wiring to the remote unit-or a break in the wiring from the main unit. Check the received voltages on the remote unit.
Posted on Dec 09, 2010
What does exactly means 'INSP' in the aircon display of GW X240 4WD?
I am not sure something inspection or service,may you have to take to dealer.
Oct 11, 2016 | Cars & Trucks
My mercedes w124 230E aircon stopped functioning
if your car gets low on freon it will sut off the compressor to geep you from burning up the compressor ,take to shop and have your freon checked
Feb 23, 2013 | Cars & Trucks
Carrier Aircon WCARG010EE 1 HP (remote) It seems the fan doesnt work, and the remote doesnt work. and there is an Fr that keeps blinking.
Dec 09, 2010 | Carrier Heating & Cooling
Aircon (cold has stopped working) had it regassed and it worked for about 2 weeks then stopped again....the garage put dye in and said there was no leak....any suggestions
Have the compressor and lines checked for leaks again using the UV light dye detector. Sometimes a slow leak that takes 1 or 2 weeks will not show up immediately.
Aug 26, 2010 | 2007 Ford Focus (3 Door) Hatchback
Car jerks when I stop only when I have air conditioner on
When the aircon is switch on it puts a substantial load to the engine: you need to get your car tuned to take into account the load from the aircon. Most car have a mechanism that increases the idle speed when the aircon is active: if you are unable to get your car tuned yet, try making the engine idle speed slighty faster while you have the aircon turn-on (the ajustment screw should be close to the accelator cable connection at your engine end). Don't make the idle speed too high and check by turning the aircon off and on to assess the best compromise idle speed to stop your car from almost stalling (e.g. jerking).
Jul 05, 2010 | 2000 Hyundai Elantra
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
Car shuts off at stop when air conditioning is on, starts right back up
Problem with Aircon clutch OR your reves are to low ,,,with aircon working revs should be about 650 rpm min
If aircon clutch then it is trying to seize up....
Sep 27, 2009 | 2005 Hyundai Tucson
Unwanted fumes gas in ford falcon futura
is the car on recirculate or fresh air? air from your aircon comes through the bottom of your front windscreen, make sure its clear and free of leaves or anything that can cause blockage to stop it from become damp inside the aircon ducts. if it is definately petrol fumes you may have an exhaust leaking from your engine bay, releasing the fumes into your cabin, that is the most common reason for petrol fumes in your aircon.
Jan 03, 2009 | 2005 Ford Futura
Onkyo FR-9GX
Try using a laser eye cleaner, this may help. ERF
Dec 23, 2006 | Onkyo MC35Tech CD Shelf System
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
