Question about Whirlpool Water Heaters
Need to know about my warrenty
The 7 digitproduct number is 6603582 the model number is fg1j4040t3nov
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
I have a Whirlpool 40 gal. electric water heater with a box on top that lights up and blinks to let you know of any problems. The other day it blinked that the upper element was defective, I installed a...
It sounds like the box is bad.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
For second opinion:
Call Whirlpool number that shows in manual.
Person answering phone will want product number and serial number that is located on label on side of tank
Manual says:
1-877-817-6750
When calling for assistance, please have the following
information ready:
1. Model Number
2. 7 Digit Product Number
3. Serial Number
4. Date of Installation
5. Place of Purchase
Dec 27, 2010 | Whirlpool Water Heaters
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a gas water heater but no hot water. What happened? Our house was built in 1994. Don't know the make - It's in the attic. Do we need to replace the thing? Is it safe? Thanks
gas appliances in the attic are never safe.
a water heaters life is 7 to 10 years. if maintained, lifespan can be a lot longer.
would need to know what brand, and model number to help repair, but most likely the thermocouple needs to be replaced.
I would actually relocate out of your attic. the only water heaters I install in attics are electric.
Jun 25, 2010 | General Electric GE SmartWater Household...
Biflame on off switch fire
LOCAL ELECTRIC SURVAYER SOLVED THE PROBLEM
THANKS ENYWAY
Oct 18, 2009 | RELIANCE ELECTRIC WATER HEATER
Code C7 76 falshes
I had the same problem. Rheem/Paloma tech support 1-800-431-1549 checked the error codes and sent me a new motherboard next day air. Since I stil needed hot water, I disconnected the remote control from the heater and it worked fine (just turn power off on remote, open front door of unit and unscreww/disconnect the 2 wires coming from the remote). The motherboard arrived and I installed and it works fine. However, you will need 1 person working on unit and one reading the codes/numbers on the remote (my unit is outdoors and the remote display is indoors, so it was not a 1-person job). Tech support was very helpful.
Oct 02, 2009 | Rheem Tankless Hot Water Heater...
Hi there, do you know what error code 82 C2 means and how I can reset the unit?
82 is a problem iwht the high altitude chip or that the circuit board data has failed you should call a rheem service rep to come fix it. rheems number is on the shell of the unit usually if you play with it. it will void the warrenty
Jul 07, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Water Heaters Logo
43 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
